Old 10-05-2004, 02:07 PM   #211
chippy's Avatar
Originally posted by Randy Caster
I have no clue on what engine to go with, I wish I could find a good one with a black head though, keep the color scheme
Try this 1
chippy is offline   Reply With Quote
Old 10-05-2004, 02:38 PM   #212
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What is it?
Old 10-05-2004, 02:46 PM   #213
chippy's Avatar
What is it?
New STS D21B buggy engine have a look in the exclusive nitro engine zone their is a thread about it there
Old 10-06-2004, 12:01 AM   #214
corradopsi's Avatar
Send a message via AIM to corradopsi
the bushing are small inserts that capture the hinge pins. the inserts fit into larger mating holes in the chassis to secure everything. by using the bushing with an offset hole in them you can change the angles the hingepins are held at by only changing the bushings. no castor blocks to change, no toe or anti-squat blocks to change. just remove 2 screws to pull the block away. pull the hingepin out of the bushings. put in the appropriate bushings for the change you want to make, and put the same block back on with 2 screws. really fast and easy to make adjustments. and the manual that comes with the car has an incredible setup section in it. you can download the manual from www.teamxray.com if your interested in reading up on it, and it also describes how adjustments are made and gives you pictures of it.
Mine: Nomadio Sensor; T2'007, Keyence, Express; ZX-5 SP, Mamba Max; XB8, OS V-spec and NR P5; ProBoat Shockwave 36
My Son: Futaba 3PM; T4 RS; Clodbuster; TT-01;Zig-Zag racer
corradopsi is offline   Reply With Quote
Old 10-06-2004, 02:04 AM   #215
mashimaro's Avatar
corradopsi- thanks a lot, now i understand it
mashimaro is offline   Reply With Quote
Old 10-06-2004, 01:49 PM   #216
Just ordered a JP FX 21 B-5N for my buggy, should be here friday or monday I hope
Old 10-06-2004, 08:47 PM   #217
coldeye's Avatar
Default dirty car
Randy,
Aren't you the guy that said you didn't want to turn marshall nitro cars because you didn't want to get your hands dirty? Maybe see ya at Revelation sometime.
Mike P.
coldeye is offline   Reply With Quote
Old 10-06-2004, 10:57 PM   #218
That's me...
I like to drive, the pitguy does the marshalling and cleaning of my car
Old 10-07-2004, 10:55 AM   #219
What aftermarket engine heads are avalible for the JP engine? It gets pretty hot here in SoCal year round..
Old 10-11-2004, 08:09 AM   #220
dkj-M3's Avatar
lol
dkj-M3 is offline   Reply With Quote
Old 10-12-2004, 01:15 PM   #221
Default FYI Cheap NR P5's
Atomic Hobbies has the Novarossi P5 (Light-weight Crank) for $269.99 1-888-44-Atomic www.atomichobbies.com
rcman1 is offline   Reply With Quote
Old 10-12-2004, 02:54 PM   #222
bigl's Avatar
Trader Rating: 31 (100%+)
what oil's are people running in there diffs
bigl is offline   Reply With Quote
Old 10-12-2004, 03:00 PM   #223
I ordered some 5k for the front, and running the stock 1 and 7 in the rear and center. Did you get your buggy yet?
Old 10-12-2004, 03:04 PM   #224
bigl's Avatar
yes i got it this morning
Old 10-13-2004, 12:46 AM   #225
It's starting to suck that there is no XRay USA yet... So far my kit came with a bent brake plate, and I'm missing the large O-Ring inside my front diff. Anyone know if its the same size as another manufacturers, or anyone have one I can just buy?
XRAY XB8/XT8 THREAD 20 SMOKE Nitro Off-Road 404 04-23-2014 06:32 PM
Xray Thread (EP,GP On & Off Road) Andrew Barr Australian Racing 100 12-24-2007 06:32 AM
XRAY XB8EC THREAD pink_sleeve Electric Off-Road 82 08-01-2007 08:28 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 08:28 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 01:51 AM
