Old 09-10-2004, 11:26 AM   #196
KY9fat's Avatar
Originally posted by TambokGT
...how can anybody BREAK an installed plastic shock piston?
where you running the buggy WITHOUT oil or something?
You tell me.... and I just did!
KY9fat is offline   Reply With Quote
Old 09-10-2004, 11:34 AM   #197
KY9fat's Avatar
Originally posted by supercross
running without using the downstops relys on the shock pistons limiting the travel of the suspension on full droop! this could easily break a shock piston!
if you wanted loadsa droop you shoulda got a 777
hopefully they will have any initial problems sorted by the time my car arrives! second shipment
You 'Need' to run the downstop on this car like I said earlier in my post or the Universals will lock up! (or do the mod recommended by Niklas)
I previously owned the MP7.5 before and I've proved that even I break A arms, C hubs, Arm holders or even bend the chassis, I know the shocks won't leak! I'll be definately getting the 777 shocks to fit this car...
Xray should have use the 'white' plastic that Tamiya uses for their shock pistons and the o ring shims at the bottom and not this hard moulded plastic which is too brittle. It's hard, but brittle!
Old 09-10-2004, 12:18 PM   #198
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I had that same problem with my xb8 and it took me out of 3 qualifiers at the last rcpro race. I did come up with a solution. Get some mugen big bore pistons they are a direct fit and will not break. I also did some limiting of the rear arms. I have the down stops sticking out of the arm 4.5 mm and it works great. I feel your pain but xray is now aware of the problem and I am confident they will fix it. I personally feel the shock shafts are about 3mm to short but we will see what they come up with. I am going to make some new shock shafts and try it out with the stock pistons.
KINGZJ is offline   Reply With Quote
Old 09-10-2004, 12:28 PM   #199
supercross's Avatar
maybe try the 777 shafts??all 3.5mm!
could be worth a go
Jesse i think you just answered a question of mine on the grid? i'm showtime on there
having some trouble with my ARD Omega
Adam Lewis - JQ Design - JQ Products - SMD - LMR - oOple - MutinyRC -
supercross is offline   Reply With Quote
Old 09-10-2004, 09:00 PM   #200
temjin006's Avatar
Send a message via AIM to temjin006
Just wanna ask if I there is room to fit a wasp 26 with pull starter on the xb8. I want to get the XB8 during the winter and put my old pull start wasp 26 in it for the cold time. Once the summer comes, I will put in a new P5. Does the engine mount included with the XB8 give enough clearance for the pull starter? i really look forward to this buggy as I have something to do during the cold months.
temjin006 is offline   Reply With Quote
Old 09-14-2004, 09:37 PM   #201
MEantime, w/o modification, putting the upper mounting in the lower hole can gain 11mm droop while shock in fully extent.
But as we know the situation will break the shock piston so raising to 14mm will clear the outdrive and kept the piston away from shock body on max. travel.
GoldFinger is offline   Reply With Quote
Old 10-04-2004, 01:57 PM   #202
bigl's Avatar
Trader Rating: 31 (100%+)
any more feed back on the car like how its holding up and what parts are people braking and so on this thread needs some input come on people
bigl is offline   Reply With Quote
Old 10-04-2004, 02:23 PM   #203
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Mine should be here on Thurs of Friday.
Old 10-04-2004, 04:06 PM   #204
bigl's Avatar
just ordered one from rc-mushroom
Old 10-04-2004, 05:27 PM   #205
Sick, we'll have to work on finding a setup for these things quick. What did you pay for it?
Old 10-04-2004, 10:16 PM   #206
psmart2's Avatar
Two races and one full day of testing. Casulties so far: 1/2 inch of fuel tubing. Cut where it attached to the fuel filter. This car is a tank, a very light and fast tank!!
psmart2 is offline   Reply With Quote
Old 10-04-2004, 10:29 PM   #207
bigl's Avatar
randy i paid 650
Old 10-04-2004, 11:06 PM   #208
bigl's Avatar
randy what motor you going to run i think im going to get a novarossi top p5 mod.
Old 10-05-2004, 01:51 AM   #209
I have no clue on what engine to go with, I wish I could find a good one with a black head though, keep the color scheme
Old 10-05-2004, 07:48 AM   #210
mashimaro's Avatar
Post Please!~
Could someone please explain how does the eccentric bushings for the I.S.S suspension adjustments work? i can't quite work it out from the infos on the xray website and the pictures on the net. Can sombody explain, thank you!
mashimaro is offline   Reply With Quote
XRAY XB8/XT8 THREAD 20 SMOKE Nitro Off-Road 404 04-23-2014 06:32 PM
Xray Thread (EP,GP On & Off Road) Andrew Barr Australian Racing 100 12-24-2007 06:32 AM
XRAY XB8EC THREAD pink_sleeve Electric Off-Road 82 08-01-2007 08:28 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 08:28 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 01:51 AM
