Old 08-25-2004, 10:45 AM   #181
KY9fat's Avatar
I've also find this car needs to use down stops, the rear at lease. If you let the rear arm drop to the lowest position, the universal will lock up!
KY9fat is offline   Reply With Quote
Old 08-25-2004, 11:48 AM   #182
Niklas Edlund's Avatar
Originally posted by Niklas Edlund
Front box in place and lower arm also. (new better, bigger picture)
Check the post I did on page 3 (in this thread) when building it a month ago. I smoothened out the edge in the outdrives with the dremel so you could use moore droop without the bones locking up in the outdrives... At the worlds we adjusted the down-stop screws after that (front and rear) so it didnt lock up. We used max droop (more then what you can have as stock).
http://www.rctech.net/forum/attachme...&postid=991526
Niklas Edlund is offline   Reply With Quote
Old 08-25-2004, 08:34 PM   #183
KY9fat's Avatar
Thanks Niklas will try when next overhaul
Old 08-25-2004, 09:59 PM   #184
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by KY9fat
Another..
You could have polished your pipe before you put it onto your new car!!
dtm is offline   Reply With Quote
Old 08-26-2004, 09:55 AM   #185
KY9fat's Avatar
What..for it to get dirty again...
Old 09-04-2004, 04:42 AM   #186
Can somebody (excluding factory drivers) give us some feedback regarding the performance of the car, ie. handling, maintenance, etc. so that we can get an idea of how well this car performs on various types of tracks.
Preferrably if you could also compare it to K3, 777 or X5.
Thanks a lot.
Lung is offline   Reply With Quote
Old 09-05-2004, 09:33 AM   #187
KY9fat's Avatar
Do you guys find your shocks leaks? I ran mine for the first time on Saturday and after about 5 tanks or so, I notice the car runs very bumpy. I check my shocks and found that it lost all its damping and some oil alraedy leak out. There were 2 other XB8 that day and they both had the same problem!
??????? Any similar experience guys?
Old 09-06-2004, 09:16 PM   #188
Dave_D's Avatar
Hmm.. I see I wasn't the only one who got the "special" diff pin..
XRAY sorted out the problem for me as well.
Dave_D is offline   Reply With Quote
Old 09-07-2004, 12:29 AM   #189
corradopsi's Avatar
Send a message via AIM to corradopsi
Talking
mine is on its way right now, picked it up for $620 shipped on ebay. i plan on getting a OS VZ-B V-spec for it and i already have a Jammin JP-1 pipe. what servo's do you guys recommend. i want digital so that i can use futaba's HRS system down the road with a reciever upgrade for my 3PM. id also like to keep servo cost under $80 each. this is going to be a race only buggy since i already have a PRP Swift for bashing and backup car. also are there any good setup sheets out for a hardpacked slick track? i know its a lot of questions but im hoping to get it all covered right the first time. thanks in advance guys.
Mine: Nomadio Sensor; T2'007, Keyence, Express; ZX-5 SP, Mamba Max; XB8, OS V-spec and NR P5; ProBoat Shockwave 36
My Son: Futaba 3PM; T4 RS; Clodbuster; TT-01;Zig-Zag racer
corradopsi is offline   Reply With Quote
Old 09-07-2004, 12:39 AM   #190
OvalEvader's Avatar
Send a message via AIM to OvalEvader
Seems like a set of Futaba 9451's will fit your budget, and criteria perfectly. I don't use an HRS system, but I use 9451's on both throttle and steering.
OvalEvader is offline   Reply With Quote
Old 09-07-2004, 10:17 AM   #191
Send a message via Yahoo to TambokGT
how does the buggy perform in racing condition?
TambokGT is offline   Reply With Quote
Old 09-10-2004, 10:07 AM   #192
KY9fat's Avatar
.......I check my shocks and found that it lost all its damping and some oil alraedy leak out. There were 2 other XB8 that day and they both had the same problem!
I know why my rear shocks don't have any damping....
Old 09-10-2004, 10:12 AM   #193
KY9fat's Avatar
Thumbs down
I'm very Suprise and Disappointed this happen on a Xray....
Guess they still need a lot of work to get a Buggy right!
Old 09-10-2004, 10:47 AM   #194
...how can anybody BREAK an installed plastic shock piston?
where you running the buggy WITHOUT oil or something?
Old 09-10-2004, 11:01 AM   #195
supercross's Avatar
running without using the downstops relys on the shock pistons limiting the travel of the suspension on full droop! this could easily break a shock piston!
if you wanted loadsa droop you shoulda got a 777
hopefully they will have any initial problems sorted by the time my car arrives! second shipment
Adam Lewis - JQ Design - JQ Products - SMD - LMR - oOple - MutinyRC -
supercross is offline   Reply With Quote
XRAY XB8/XT8 THREAD 20 SMOKE Nitro Off-Road 404 04-23-2014 06:32 PM
Xray Thread (EP,GP On & Off Road) Andrew Barr Australian Racing 100 12-24-2007 06:32 AM
XRAY XB8EC THREAD pink_sleeve Electric Off-Road 82 08-01-2007 08:28 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 08:28 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 01:51 AM
