Old 08-23-2004, 10:37 AM   #166
KY9fat's Avatar
Another..
KY9fat is offline   Reply With Quote
Old 08-23-2004, 10:38 AM   #167
KY9fat's Avatar
Last one..
Old 08-23-2004, 06:40 PM   #168
SupermaxxRich's Avatar
looks sweet! can't wait to get mine. what is this "wave pattern one from Gandini" filter and where can I get it from?
SupermaxxRich is offline   Reply With Quote
Old 08-23-2004, 06:59 PM   #169
Bandicoot's Avatar
Hey KY9fat, what is that grey stuff around your stinger? Is that JB weld? What is it for?
Bandicoot is offline   Reply With Quote
Old 08-23-2004, 07:14 PM   #170
The epoxy or JB Wels helps prevent the stinger from getting blown off in a hard crash. I don't use that stuff thou, makes the pipe look yucky.
Old 08-23-2004, 07:15 PM   #171
Originally posted by KY9fat
Hi Guys,
I bet I'm the lucky guys here. Look what I've found in my XB8 kit
What are those that you found?
Old 08-23-2004, 07:21 PM   #172
Bandicoot's Avatar
They look like diff shafts for the spur gears, the groove should be in the same location on each shaft so that when they cross there is even length on each side. One of the shafts is off and would not line up at assembly it looks like. The diffs look alot like the Mugen diffs. Has anyone ran the car long enough to know if the Xray diffs leak like the Mugens?
Old 08-23-2004, 07:24 PM   #173
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
WOW that's a nice buggy....
Man, If I owned one of those, I'd be showing off those cool Xray rims!
LosiFromHell986 is offline   Reply With Quote
Old 08-23-2004, 11:39 PM   #174
supercross's Avatar
i don't know why everyone bangs on about MBX5 diffs leaking?
i've run an MBX5 for the last 9 months & my diffs have Never leaked!
Adam Lewis - JQ Design - JQ Products - SMD - LMR - oOple - MutinyRC -
supercross is offline   Reply With Quote
Old 08-24-2004, 12:36 AM   #175
Niklas Edlund's Avatar
Its the same manufacturer (I think) as the original XB8 filter but the outer diameter on the first grey filter is shaped in a wave pattern or "zig-zag"... Its still new (introduced at the worlds) so I dont know if even GRP (Gandini Racing Products in Italy) has even started to export them yet...
Niklas Edlund is offline   Reply With Quote
Old 08-24-2004, 10:05 AM   #176
KY9fat's Avatar
.....Better protection than Yucky.. same as using a condom
Old 08-24-2004, 10:22 AM   #177
KY9fat's Avatar
Correct. The shafts should be same length but I got a bad one.
Actually all makes of diff are similar. I've own a kyosho MP7.5 before and it is the same design. As for leaking diff, It depends on how well you build it and make sure the contact space on the gasket is clean. What I used to do on my 1/10 MTX is use double gasket and a layer of silicon (Glass glue).
One thing about the Xray diff is it uses an 'o' ring on the back of the smaller gears (grooved). It use this config in the Front and center diff, and not the rear. This gives the diff a "stiffer" feel. I'm worry that when the o ring starts to aged, the diff will have different feel and need re-building a lot.
Well, we'll see...
Apart from the little pin, the kit was excellent, as always Xray.
Old 08-24-2004, 10:55 AM   #178
supercross's Avatar
that extra O ring idea is just the same as thre Mugen diffs
you'll get a much more consistant diff action if you leave the O rings out & just use stiffer silicone
it was said somewhere that the O rings will add about 2-3,000 in stiffness to the oil you use!
well thats when they're new anyway, it'll get rapidly less as they wear! thats why stiffer silicone would be more suitable
Old 08-24-2004, 11:37 AM   #179
Well, we'll see...
On the prototype XB8 we liked the small satelite gear o-rings but on the production cars for the worlds we did'nt like them any more... We all thought that they seem to be a little un-consistent in their action with them in at Furulund.
The diffs also are small so it seems that they are "harder" by design. Tip: dont fill them more then just about to the center of the shafts or just slightly more...
Old 08-24-2004, 10:15 PM   #180
Is there any initial setup suggested?
I mean other than stock one?
GoldFinger is offline   Reply With Quote
XRAY XB8/XT8 THREAD 20 SMOKE Nitro Off-Road 404 04-23-2014 06:32 PM
Xray Thread (EP,GP On & Off Road) Andrew Barr Australian Racing 100 12-24-2007 06:32 AM
XRAY XB8EC THREAD pink_sleeve Electric Off-Road 82 08-01-2007 08:28 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 08:28 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 01:51 AM
