what do these #'s mean?
I'm not a big electric user and can't remember what these #'s mean from my charger.
6 cell GP3300 - TrC 0314 / 8.919 V / 9.827 Vp
7 cell Racers Edge 3300 - TrC 0360 / 10.176 V / 10.993 Vp
It doesn't seem like these batteries last long anymore so I wanted to check and see if they're any good? What do those #'s tell me?
Thanks!
Thanks!
Thanks!
Thanks!
7 cell 3300 mAh battery 10.176 volts, 10.933 peak
You could probably cycle them (charge/discharge) at a low rate a couple of times to see if you can improve the run time. Other than that if the batteries are old they may have seen better days.
Seems like it but the real test is when you run them. Give them a couple of cycles and then run them to see where you stand.
The noticeable self discharge is something you notice with old batts. It gets worse if they've been sitting a long long time. I have a set that dumps in a few days, but they do fine if charged and then used as soon as possible.
You may see some improvement after a few cycles, you may not, hard to tell since it depends on internal condition of the cells.
