losi 8 2.0 buggy smartdiff with electric
if i convert my 8 2.0 buggy to electric with the tekno kit, are smart diffs still a good upgrade???
Im running the CSD and i like it so far ! Going to try the FSD next season
In electric trim, the center smart diff really frees up the buggy upon rotation thru the turns. If you are used to the std gear diff, this option will make the buggy feel "loose" in the turns, but once you get used to it, it definately makes a difference. There is a drawback, the std gear diff is bulletproof...and the smart diff requires alot of maintenance. In my opinion, you cannot simply drop it in and run it for more than one race weekend without a rebuild. If you take your cars down every race, the SD is a great option. But if you are on the other end of the spektrum...well you get the point. Also, I've tried the front SD, and I personally did not like it. Made the car very "darty" and hard to drive on rough tracks. I hope this helps....
-CB
-CB
-CB
-CB
I have the Center Smart Diff and it doesn't seem to lock up at all. (There is almost no torque to the rear wheels). Maybe it is because I am using the kyosho plastic spur, i am not sure. I've rebuilt it at least three times with no luck. Before I give up, I will try 10K fluid so it will at least act as a normal diff.
try stiffer springs I put in 2 3.5 with the grease still never snappy loose on cracking the throttle , just pulls , I think it kinda gives the clutch effect. jmnbo
