help
help
i have a xtm truggy and i dont want to solder the wires too the motor through the speed controller any assistance can i make the solder stick together doing somthing other than soldering
You can soilder wires on to the motor and put a deans plug on it.
I'm running stock and super stock classes motors in my B4 and instead of soldering and unsoldering all the time on my Tekin RS w/13.5 and 17.5 motors I bought a couple packs of 4mm bullet connectors from Tekin and put them in between the motor and ESC. Now when I want to switch back and forth it's plug and play. Works great and is a helluva lot faster then soldering all the time.
If you are into electric you better go ahead and learn to solder. With a nick like that you should be able to handle it.
