Mamba 2650kV on 2S lipo in 1/8 Buggy?
Looking at the speed calculator, I should be able to get around 40mph ( which I have been told is a good number to aim for ) while running 18t pinion with 44t spur on 2S lipo.
Since I've already got some 2S 5000mah 30C lipos, it would save me some cash. And it should save some weight as well.
I'm just not sure if this would put too much stress on either the motor or ESC. So is there a way of figuring out if either of these will be stressed too much without actually running it? And also, how would I be able to get an idea of runtimes?
Thanks for the help!
I'm running the MMM 2650kv in my rc8 and running 2 2s lipos together for a total of 14.8volts and have no stress issues here.
matt
matt
What kind of runtimes and motor temps are you getting matt?
Cheers,
Peter
Matt
Matt
It will not work properly
you will have heat issues eve if your lipos can even get it to 40mph which is doubtful, its gonna be pulling insane amps to go that fast on 2s, more than likely the lipo will be the weak link.
you could go 3s (youll need a very good one!)
or you can use two of your current 2s 5000 30c lipos in series and gear it down to 35-40 and then you wont have problems.
my suggestion would be to buy the car its own lipo that can handle it
rc-monster.com has these two lipos instock that would easily handle that 2650 geared for what you want.
HYPERION G3 VX 5000 MAH 4S 14.8V 35C/65C
or
HYPERION G3 VX 5500 MAH 3S 11.1V 35C/65C
if you go with the 3s setup i suggest to start off around 35 if you do the 4s setup go for 37-38
both would work well.
or
Well I decided I'm going to try the 2200kv with 4s lipo. I'd like to be able to run it on either my buggy or truggy. So I'm gonna try the 16t pinion for the buggy, and 13t pinion for the truggy, which is the same as the clutchbells I'm currently running. I can't wait for all the gear to turn up now!
I raced my 1/8 with mamba 2650Kv & 5000 mah 2S 30C pack. Speedo & motor are running very cool about 100 deg on speedo and 110 deg on motor. I geared 2 teeth higher with 2S than a 3S. I don't know if U can get 40mph on a 2S battery pack. For me it's a lot easier to control on 2S than 3S.
look into running a smaller motor with bigger lipos,I run a tekin 1500kv motor on 6s and its just as fast as a 2650kv on 4 cell and runs right at 105 after a 15 minute main,if you can keep the temp down the esc and motor will last a lot longer
