Slash acceleration---loose rear >
Old 10-08-2009, 08:56 PM
Trader Rating: 22 (100%+)
Default Slash acceleration---loose rear
Under hard acceleration on a straight way, the car spin 360 and rear end comes real loose and weaving...any idea on how to fix it???
I try to have a smooth take off....please help.,..thanks
xxx123 is offline
Old 10-08-2009, 08:57 PM
Trader Rating: 23 (100%+)
your tires are spinning, easy on the throttle and loosen your slipper clutch a bit.
not home is offline
Old 10-08-2009, 08:58 PM
snowboard094's Avatar
Brushless??
snowboard094 is offline
Old 10-08-2009, 09:07 PM
yes brushless..even brush i have the same problem,,thanks guys
xxx123 is offline
Old 10-08-2009, 09:10 PM
Timbulb's Avatar
Welcome to Short-course truck racing. Learn how to drive it without being on the throttle 100% all the time.
Timbulb is offline
Old 10-08-2009, 09:11 PM
fabolousRC's Avatar
Let see...diff too tight? Was it like this when brand new or did you just rebuilt it? Check tire wear. Check shock fuild; too stiff no traction. Check camber. Check ESC punch. Check dogbone wear and make sure they're still attach to the diff.
fabolousRC is offline
Old 10-08-2009, 09:57 PM
You also might want to look into some better tires for your track conditions. More traction will help.
Old 10-08-2009, 10:01 PM
RcRacing4Ever's Avatar
Roll the throttle & try putting these hubs on to add 1.5 degrees of toe... #4352
RcRacing4Ever is offline
Old 10-09-2009, 06:33 AM
R/C Tech Elite Member
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
I had that problem under hard acceleration,,, the body was to low, and rubbing the rear tires.
Mac The Knife is offline
Old 10-09-2009, 09:56 AM
DJ919's Avatar
using the stock body? ...That happens...The Proline Desert Rat body has a bit more rear tire clearance, but still rubs every now and then.
DJ919 is offline
Old 10-09-2009, 10:38 AM
scr8e's Avatar
my slash was too light up front under full throttle and wouldnt track, I lightened my spring and oil rate up front and moved my battery forward as far as I could. A light front mounted swaybar helped stability in corners. Loosen slipper first
scr8e is offline
