pinion/spur gear setup for b4?? please help. newbie here >
Old 10-08-2009, 04:38 AM
Exclamation pinion/spur gear setup for b4?? please help. newbie here
i just bought a b4, and i ordered a tekin rs pro and redline 13.5t motor. what should i buy for pinion and spur gear combos? please help!!!
iraqsucks is offline
Old 10-08-2009, 08:09 AM
Trader Rating: 19 (100%+)
Is your racetrack big or small?
b4wires is offline
Old 10-08-2009, 08:35 AM
i dont know what you would call big. its middle sized if i had to guess.
Old 10-08-2009, 08:37 AM
Trader Rating: 12 (93%+)
Measure it in length that will help us all out. I run 78/24 at LIR its a medium /small track we run around 20-25 seconds per lap.
Here is a Great site that I was given. I have donated to it because it is amazing.
R/C Calculations
If you have any questions feel free to ask
killatoyota4569 is offline
Old 10-08-2009, 06:06 PM
well im guessing its larger than yours... it about 70 ft long and it has 6 lanes. with some serious straights.
Old 10-09-2009, 01:04 PM
ok, so whats the smallest spur and largest pinion i can run? safely without overheating my motor? i want some good accelleration...
Old 10-09-2009, 06:26 PM
Trader Rating: 17 (100%+)
The largest pinion and smallest spur will kill your acceleration and make your motor overheat.
I would start with a 25 tooth pinion on your stock spur. If you need more top speed you can go up from there but I would check temps often. Keep the motor under 180F and you can do just about whatever you like.
burnineyes is offline
Old 10-09-2009, 10:44 PM
81t is stock?
Old 10-12-2009, 07:56 AM
RC Dad's Avatar
Trader Rating: 26 (100%+)
I'd agree that 25-26T is a good place to start. With the RS Pro you can use Boost or Turbo features to get the top end if needed for that 1 extra second at the end of the straight, no point in overgearing.
RC Dad is offline
Old 10-12-2009, 08:36 AM
cub2's Avatar
Originally Posted by iraqsucks
81t is stock?
i am runing 78/26 on my car and i am runing a 10.5. So if you are runing a 13.5 i would start at 78/28 and go from there.
cub2 is offline
Old 10-18-2009, 07:58 PM
R/C Tech Elite Member
Trader Rating: 520 (100%+)
I run Tekin stuff also, and I had my 13.5 geared at 72/29-31 depending on track conditions, make a few laps and check your motor temp. A 13.5 with an RS pro you really wont have too many issues with the esc, but keep the motor below 180*
flame56mx is offline
Old 10-18-2009, 08:18 PM
Trader Rating: 23 (100%+)
ask people what they are running and gear down a bit cuz u got the tekin
not home is offline
Old 10-18-2009, 08:35 PM
??? have you run Tekin before ???
Old 10-19-2009, 05:27 AM
when i had a 13.5 in my b4 i was running 72/34 and it would come off the track around 145-150, but the track i was doing that at was kinda small
xllivillx is offline
Old 10-19-2009, 07:30 PM
What are you running for ESC, Motors?
