Old 03-13-2004, 02:24 AM   #16
cannon's Avatar
Trader Rating: 35 (100%+)
If you think that this was abusive then you are a lost cause. Notice the smiling faces nodding...hardly a bagging. I even suggested the tyre he should be using on his home track. I haven't put one abusive post on any thread yet..BTW if you want to use the word "thought", at least spell it right.
cannon is offline   Reply With Quote
Old 03-13-2004, 02:34 AM   #17
Gee you must of really studied that post,
Maybe you should change your name to loose Cannon,
And you know what part I'm talking about.
Yeah you want to ride it don't you.
rcnobjockey is offline   Reply With Quote
Old 03-13-2004, 03:26 AM   #18
cannon's Avatar
No not really, it's just that you have done it on two posts already. You are getting boring because unlike Timmy2Quick you are not funny.
Old 03-13-2004, 04:26 AM   #19
cannon's Avatar
Ybakoff - if you are using kit set up this usually includes M3 front tyres....they can be too grippy at Castle Hill....makes to the buggy throw the rear out....try using R3 compound....they are more consistent
Old 03-13-2004, 07:48 AM   #20
Ybakoff's Avatar
Gee Boys.
If I had of known that by asking a question about handling was going to start a fight I would of just asked my Nana. Even know she doesn't know what she's talking about would of saved everyone getting upset.
Ybakoff is offline   Reply With Quote
Old 03-15-2004, 02:06 AM   #21
cannon's Avatar
Looks like the handling problems vanished looking at last weekends results...good racing
Old 03-15-2004, 02:16 AM   #22
Ybakoff's Avatar
Must of been the 8081's. Have to get myself some of those.
Plus I think that I got lucky. Daddy was a mobile chicane, poor old Nath had an extra few corners every lap.
Old 03-15-2004, 02:25 AM   #23
cannon's Avatar
I think Nath's problems came out of a glass the night before....did you see his eyes....OUCH
Old 03-15-2004, 02:42 AM   #24
Ybakoff's Avatar
Yeah a few to many roadies.
I swear Glenn has a few every Sunday before he races. Otherwise he's just unbalanced. He rocks side to side on the stand whenever he gets into a battle. Maybe he needs a couple of spare legs. Like Balkey.
Old 03-15-2004, 02:47 AM   #25
cannon's Avatar
You should stand between him & Brian...you get sea sick from the motion and the moving radios block your view of your car
Old 03-15-2004, 08:28 AM   #26
hobbipro's Avatar
Trader Rating: 21 (100%+)
Practice,practice,practice, Thats the name of the game. I personally like Billy Eastons set up on www.rc10.com. I use this on a smooth, clay, hard packed track with mini-pins. I slide the battery to adjust if I want more front/rear bite.
hobbipro is offline   Reply With Quote
Old 03-17-2004, 08:00 AM   #27
warpig's Avatar
I run a b4..
mine did the same thing...
I thought I had the ride height adjusted properly.. I drive with an associated sponsored pro occasionally.. he said to adjust the height.. just press down on the body.. about 1/2" and let go and check..
basically my ride height was too low front and back.. as was causing weird stuff to happen I don't even know for sure why.. I thought lower would be more hooked up.. but, it let go of the rear on every turn and wouldn't steer worth a darn...
front arms level
rear bones above level
It could be something else also... like limiter problems in shocks
warpig is offline   Reply With Quote
Old 03-17-2004, 09:55 AM   #28
JoshR 85's Avatar
HeY!!!
How do you guys like your B4??? i'm thinking of getting one and are there any tips to building the kit???
JoshR 85 is offline   Reply With Quote
Old 03-17-2004, 06:59 PM   #29
warpig's Avatar
I tell ya... setups range a lot on this car.. everyone seems to have something different.. but, one thing.. I highly suggest the blue o-rings MIP make for the shocks.. unobtanium shafts, and HPI shock bladders.. part #: HPI6814
Old 03-17-2004, 07:19 PM   #30
JoshR 85's Avatar
HeY!!!
i saw that someone down where i race was using T4 front blue springs for his B4, and it looked to be hooking up pretty good he took 1st in main, and qualified 2nd
tyre wear & handling problem J-PaP Australian Racing 17 02-02-2007 03:20 PM
handling... rcspeedtuner Rookie Zone 4 11-12-2006 08:44 AM
xxx-nt handling PSiDAWD Electric Off-Road 15 05-03-2006 03:36 PM
Major Handling Problem V1-RRR-WC Nitro On-Road 21 01-23-2006 09:18 AM
Handling help Interceptor Electric On-Road 9 10-02-2001 07:24 PM
