Kyosho MP9E Thread
#2971
So I bought an mp9e almost a year ago(used). I'm now going through it and updating it to what I need (thanks to a good buddy). But as I'm going through I'm taking the car apart to rebuild it just to get my own setup on it. I get to the diffs to find out that as of now the center and rear diff is using only 1 pair of the spider gears in the diff. Never did this on my nitro mp9'stuff back a few years ago (last time I raced 8th scale.) Just curious if I got taken on this deal or if people actually do this?
#2973
#2974
Does anyone have some setup advice for the Revelation Raceway track in Ontario?
- pinion
- shocks
- suspension points
- diffs
- pinion
- shocks
- suspension points
- diffs
#2975
I have a used tki3 on the way, is it worth putting any of the tki4 parts on it whilst doing the re build??
#2976
Hi, the wing tower is much better. I m using it with the new wing as well. The old one is broken easily with the old tower. That s why they have improve it. I have a mp9e.
#2977
You should make the arm switch for sure . Then drive your track a few times and see if you want the car to be more aggressive. If you do , take all the kick up out of the front of the car and see if you like it . IF you do , then swapping over to the TKI4 parts is for you ... My e buggy is still tki3 and is very easy to drive when my track is loose and bumpy , my 4 is faster when the track has a lot of bite.
#2978
Thanks for the reply! I'll go ahead and get the arms fitted and see how we go from there!
#2979
Anyone have a decent setup for a TKI3 ebuggy on a hardpack, bumpy outdoor track that get a good grove by the mains. Typical U.S. outdoor track flowing with big hits.
Triple Dees - Green
Reflexs - Green or Blue
Megabites
Are the tires of choice
Triple Dees - Green
Megabites
#2980
hey guys! Just bought the conversion kit for my 777 Sp2. Figured i would get that going since it's clean for cheap, since it's easier to buy the electronics needed and not a whole kit on top of that too.
I got a HW XR8 SCT and G2 1900kv motor, with SMC 5200mah 90c 4S battery. Hopefully the battery will fit the tray.
My Q is that the Kyosho kit seems to come with a 10t pinion. Is there any way this would be OK? I run on a fairly tight track and seems most people run around a 15t pinion so 10 seems low to me.
Also, any latest bodies that might fit my converted 777sp2? A lot of the threads I have been reading through reference older discontinued bodies. Maybe the Mp9e body will fit?
thanks!
thanks!
#2981
Will this work with the MP9E TKI4? I know it says it is compatible on the Amain website but wanted to verify here.
https://www.amainhobbies.com/kyosho-...fb009h/p499623
#2982
Also have to keep an eye on where you motor tabs are. Install the motor so tabs are at the side, not on top.
#2983
Any tips on mounting the transponder? I was unsure of what works best.
#2985
I was thinking about doing that, was just unsure .
Thank you for the help!
