Like Tree42Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 05-04-2019, 05:04 PM
  #3316
I use a 4s hard case such as the Fantom low profile - about 138mm in length. With the kit supplied foam it fits like a glove as do my other hardcase lipos. I believe some tracks/rules frown upon use of soft case lipo if that’s what you refer to as standard.
Matty A is offline
Old 05-04-2019, 07:22 PM
  #3317
KoP
Hey Matty. What is the kit supplied Foam you speak of? I cannot think of any foam in my box.
I took my incompleted car car to the LHS today and found that the ProTek 5600 hard case batteries fit nicely, front to rear, with a couple mm to spare. I had them order up two Protek 6500mah HV lipos for me as they are only 1mm longer than the 5600.
KoP is offline
Old 05-05-2019, 03:26 AM
  #3318
Apologies you are correct I must have used some of the adhesive foam left over from my previous K buggy. If you can get some I would recommend it - 5mm thick..
Matty A is offline
Old 05-10-2019, 03:38 PM
  #3319
KoP
Hey my Evo came to life for the first time today!!
have the ESC mostly programmed now. Just need to figure the low voltage cutoff for my batteries.
Now i I need to build up the shocks, and add the wing !!
KoP is offline
Old 05-12-2019, 08:53 PM
  #3320
KoP
Default Finished and time to add dirt
RTR body for now
KoP is offline
Old 05-14-2019, 08:12 AM
  #3321
tak4's Avatar
More than seven years of hard racing and it's still an amazing drive. Started as a standard mp9... then an Mp9e, then Tki1 and now it's probably a Tki2.5.
Did a full tear down and rebuild yesterday and after switching out some worn out parts and bearings, and rebuilding all the diffs, it's driving as well as I could ever remember. I wont say it drives like new but it doesn't feel like its lacking anything.
It was never the fastest due to driver limitations but it sure seemed like the easiest car to drive on the track... I look forward to owning an Evo or an Mp10e one day but this still puts a smile on my face every time.
Matty A likes this.
tak4 is offline
Old 05-14-2019, 10:28 PM
  #3322
Default Front shock tower
Hey guys I was just wondering for a outdoor bike track which shock tower is better the MS OR S and is there really a difference I've been running it with the MS since I got it but a few months ago I realized when I bought the car there was like 6 sets of shock towers and thought it was weird lol so when I seen the different sizes I got confused ( not the brightest bulb lol) I tried to look up on all my pro set up sheets and only found 2 that had it in thier and it was Tebo and he used the small one can some one give me advice please I'm new to rc and have owned tlr and kyosho and guess what I stuck with lol I also have the zx6.6 to but to brittle thanks guys
Bigv is offline
Old 05-14-2019, 10:41 PM
  #3323
Default Hi there
Originally Posted by D1360 View Post
Those of you who has hollowed the battery tray, do you mount your esc directly on the chassis?
I did and it works perfect Nd handle way better
Bigv is offline
Old 05-14-2019, 10:45 PM
  #3324
Default Hi there
Originally Posted by 91junior View Post
No, a few boys have killed escís by doing this due to vibrations (probably from over jumping the landings). Not sure why or how when this doesnít seem to happen in 1/10 scale. I always use thick double sided tape and apply two layers for a bit of safety precautions. I havenít killed an ESC yet.
I use show goo and it takes vibration away
Bigv is offline
Old 05-15-2019, 05:49 PM
  #3325
The MS tower needs to be used in conjunction with the medium shocks 50mm. If you didn't get those then your standard shocks will affect droop as they won't extend as far. The HS mount was supposedly for "high speed" but good luck picking up the difference to the standard. If you're bashing on a bike track - assuming big air - I'd use the MS mount if you have the 50mm shocks otherwise use the standard mount etc and use thick oils so to avoid slapping the ground. preservation before performance....
Matty A is offline
Old 05-21-2019, 05:41 AM
  #3326
MikaR's Avatar
hi, anyone using short packs with the Evo ? how about mounting ?
MikaR is offline
