Like Tree37Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 05-18-2018, 06:36 PM
  #3106
rcbuggy88's Avatar
New front arms for tki4. Lots better and more durable. A little change in geometry though.
rcbuggy88 is offline
Old 05-19-2018, 05:57 PM
  #3107
tobamiester's Avatar
Trader Rating: 301 (100%+)
Or use these arms, have webbing like the TKI4, same geometry as TKI3.
IF493 Front Arm (Updated MP9 front arms replaces IF427B as a direct fit. Left and right.)
tobamiester is offline
Old 05-19-2018, 07:23 PM
  #3108
Default Mp9e
so iv just done my first complete tear down and clean, as well as differential maintenance. Iím to the point in the re assembly that the motor mount as been put back on the chassis , with The motor and all differentials and shafts attaches. However after tightening everything down the center differential has a lot of wiggle and the bearing doesnít stay seated correctly to the mount and the spur rubs the chassis. It wasnít like this before what did I miss? Iíve taken it all off and put it back on three times . Help!
Danknastyy is offline
Old 05-20-2018, 12:28 AM
  #3109
not 100% sure where u went wrong but u should shim the diff in the way that it fits securely and doesn't rub the chassis.
diff shims can be bought from basically any rc shop, i know kyosho sell them in batches of 10 under part number 96772 $4 us dollars from amain
https://www.amainhobbies.com/kyosho-...yo96772/p37363
hope this helps
EnthusiastBurst is offline
Old 05-20-2018, 07:38 AM
  #3110
hope this helps
well i looked over the manual again and thereís no directions for any shims on the center diff and there werenít any shims when I disassembled
Old 05-21-2018, 03:22 AM
  #3111
well im not entirely too sure but shimming the diff sounds like its going to fix ur problem
Old 05-21-2018, 06:00 AM
  #3112
Iím an idiot and didnít have the second carriage type deal on the front end of the diff. I fixed it 😂
EnthusiastBurst likes this.
Old 05-21-2018, 09:50 AM
  #3113
So the tki4 kit is no longer on amain and tower is out of stock. Is there a new kit coming?
windellmc is offline
Old 05-21-2018, 04:09 PM
  #3114
im getting ready to order the springs what length springs work best for these?
Old 05-21-2018, 05:17 PM
  #3115
rcbuggy88's Avatar
Maybe a 10th anniversary like the nitro version?
  #3116
rcbuggy88's Avatar
Really depends on your track.
Old 05-23-2018, 03:47 AM
  #3117
iíd get the shock kits throug DollarHobbyz (10th Anniversay Kits). For less cost youíll also get springs and the 8x1.3 piston and not the one off the tree.
Matty A is offline
Old 05-27-2018, 06:40 PM
  #3118
jag5508's Avatar
Trader Rating: 15 (100%+)
Anyone running the plastic spur ? If so what do you need to change ? I have a couple of extra diffs not sure exactly what I need if anything .
jag5508 is offline
Old 05-27-2018, 06:43 PM
  #3119
shouldn't need any change: direct fit, just make sure to take the o-ring from the old one
Old 05-27-2018, 06:56 PM
  #3120
jag5508's Avatar
I thought someone said you need a different diff cup then the original center ?
jag5508 is offline
