Like Tree37Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 05-09-2018, 04:48 AM
  #3091
also Kanai displayed the updates between tki3 and tki4 here; https://www.facebook.com/permalink.p...42934792424362
EnthusiastBurst is offline
Old 05-11-2018, 05:22 PM
  #3092
jag5508's Avatar
Trader Rating: 14 (100%+)
Is there anything you'd change first from from the tki3 to the tki4? What makes the most difference ?
jag5508 is offline
Old 05-13-2018, 11:50 AM
  #3093
if you donít run on a smooth track donít change anything. The next step is the tki4 b block, knuckles, steering tie rods, and 16 or 17.5 degree caster blocks.
windellmc is online now
Old 05-13-2018, 03:35 PM
  #3094
jag5508's Avatar
Originally Posted by windellmc View Post
if you don’t run on a smooth track don’t change anything. The next step is the tki4 b block, knuckles, steering tie rods, and 16 or 17.5 degree caster blocks.
I did the front shocks last year I think they were the 50mm. Is that what the TKI4 has? I was thinking of doing the wing mount and body are those direct fits? Also are diffs and cases the same?
jag5508 is offline
Old 05-13-2018, 05:48 PM
  #3095
Default Mp9e tool kit
what tool kit fits the mp9e? Is it metric tool kits? Any nice suggested tool kits with a case under 75$ ?
Danknastyy is offline
Old 05-13-2018, 06:07 PM
  #3096
jag5508's Avatar
Yes metric . MIP tools are good is far as allens . Nut drivers are good too . But you can probably get any brand they don't strip like cheap allen wrenches .
jag5508 is offline
Old 05-13-2018, 07:21 PM
  #3097
Iím looking for a all in one type kit Iv seen them from 50+ to 300
Old 05-14-2018, 09:18 AM
  #3098
tobamiester's Avatar
Trader Rating: 300 (100%+)
Get (1.5,2 & 2.5) and https://www.amainhobbies.com/mip-tho...ip9502/p261254 and a 3mm
https://www.amainhobbies.com/mip-tho...mip9011/p14521 and 5.5 and 7m nut drivers
and https://www.amainhobbies.com/mip-met...ip9503/p585637
That should be all you need. MIP are one of the best.
tobamiester is offline
Old 05-14-2018, 05:59 PM
  #3099
rcbuggy88's Avatar
+1 MIP
rcbuggy88 is offline
Old 05-15-2018, 01:02 AM
  #3100
Originally Posted by rcbuggy88 View Post
+1 MIP
same bro
Old 05-15-2018, 01:04 AM
  #3101
bulkheads are same
​​​​​​​i imagine diffs are same
Old 05-16-2018, 08:14 PM
  #3102
Shocks are different color but that is the only difference other than shock pistons but again use the tki3 parts. The longer front shocks are an option for either car and there is a different shock tower for those. Diffs are the same. Wing mount may be different and the bodies are interchangeable.
Old 05-18-2018, 07:26 AM
  #3103
jag5508's Avatar
What are you running for pistons and oil? I don't remember what I have in there. I haven't touched the car in a year.
jag5508 is offline
Old 05-18-2018, 09:50 AM
  #3104
What size turnbuckle wrench for mp9e tki ready set ?
Old 05-18-2018, 05:00 PM
  #3105
In the latest iterations of the MP9, have there been any improvements to the durability of the front A arms? I have a pair of MP9's that are both electric and I've always had a bad time keeping front a-arms alive. I always blamed the extra weight of the electric set up.
cdub_OffRoad is offline
