Like Tree37Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 03-27-2018, 03:06 PM
  #3061
Originally Posted by CRaZeD View Post
IFB008 is the part# for the nitro body
Thank you, I think that's the one I have but I will need a new one soon enough with how bad I drive haha
Jdemello is offline
Old 03-28-2018, 12:19 PM
  #3062
TZ
Originally Posted by jonlil77 View Post
Has anybody tried the M2C split center mount yet? If so did you end up with center diff moving up and down due to incorrect tolerance? Yes it is installed correctly. I have emailed them but yet to get a response.
Never tried the split diff holder in ebug, can you get the diff out without pulling the bottom screws?
TZ is offline
Old 04-02-2018, 10:56 PM
  #3063
Flotiguan's Avatar
Default What battery?
My brother jus got a Mp9e TKI. what is a good battery for it? any suggestions
Flotiguan is offline
Old 04-04-2018, 06:09 AM
  #3064
TZ
I've had good luck with these
https://www.smc-racing.net/index.php...product_id=175
TZ is offline
Old 04-07-2018, 10:49 AM
  #3065
I've been running a 16pinion on the mp9e motor temp has been fine but just dropped it down to 14 to hopefully get more low end out of the hole speed.
Running a HW combo 2200
The spur is stock (anyone know what stock is?)
What do you run on a close tight track?
Jdemello is offline
Old 04-09-2018, 09:03 AM
  #3066
TZ
stock spur is 46
you want your motor to just finish revving out just before you get on the brakes at the end of the longest straight away.
sometimes it is hard to hear this on electric, over revving
will cause it to overheat too.
TZ is offline
Old 04-09-2018, 04:30 PM
  #3067
Originally Posted by TZ View Post
stock spur is 46
Thank you, this track has very little straight away and mostly turns and jumps. Changing to this lower pinion made a world of difference for my speed and getting out of corners. I can't wait to get the time tracker and see how much better i'm doing now. I also lowered the gear on my losi 8 truggy but I think I may have gone to low on that one, the motor was overheating. BUT I also had a battery go bad so that may have caused it as well.
Jdemello is offline
Old 04-21-2018, 03:40 PM
  #3068
Hi, i'm a new owner of the MP9e TKI4, currently running a tekin rx8 and smc 1900kv with a hitec hs7940th and am loving it so far (experiencing some turning issues but believe a glitch buster should fix it).
I was just wondering what bodies could fit other than the stock MP9e body? I've come across the Bittydesign Force MP9 TKI4 nitro body which i really like the look of but concerned whether it will fit over a 4s lipo pack.
Any help would be greatly appereciated.
Cheers
EnthusiastBurst is offline
Old 04-23-2018, 01:58 AM
  #3069
Cheers
You might try this one:
LeadFinger Racing Assassin Body
LFR
BR
kurobox is offline
Old 04-23-2018, 02:44 AM
  #3070
BR
Ok thanks,
Old 04-27-2018, 04:02 PM
  #3071
What hop ops for the Tki4e are recommend; i have the 13˚ Alu. front hub carriers, titanium turnbuckle and screw sets, and other aluminium hop ups like wing brace and suspension holders. Just asking for opinion on other upgrade parts and whether or not to get them
Old 04-27-2018, 05:39 PM
  #3072
shannow's Avatar
TKI3 B plate.
shannow is offline
Old 04-29-2018, 07:37 AM
  #3073
Default Mp9e tki readyset
What servo does everyone suggest? Iím not looking to change out the stock motor just yet . need more practice first. But I feel like the stock Servo is slow. Any suggestions ?
Danknastyy is offline
Old 04-29-2018, 02:51 PM
  #3074
BlueBird servos got mad torque and speed, decent reliability and its fairly cheap from rcmart or ebay
Old 04-29-2018, 04:48 PM
  #3075
rcbuggy88's Avatar
Servos
I have no experience with BlueBird servos so I can't really comment on those. Savox has some really good budget servos and they sell replacement gears basically everywhere. I doubt that you would be able to find some replacement gears for the BlueBird servos easily. Get one with at least 150 oz-in of torque (more will help) and a speed of 0.15 sec/60degrees. I run the Sanwa PGS servos in my eighth scale cars and they work great but are quite expensive. Here is a great servo for your purposes and is on the cheaper side.
https://www.amainhobbies.com/savox-s...1268sg/p183318
Hop-ups
17.5 casters (personal preference for big tracks)
Tki3 b-plate is also popular (also personal preference)
lightweight diff shafts
maybe some skid plates if your track is rough
all the tuning stuff like front wings, springs, oils, pistons, etc... (I like the 8 hole pistons better)
all the cool titanium and gunmetal stuff to make the car look cool
This isn't really a hop-up but you can mod the battery case so that you can fit the normal Tki4 nitro body on. It will give different handling characteristics. (Jared Tebo does it )
rcbuggy88 is offline
