Kyosho MP9E Thread >
Kyosho MP9E Thread
Like Tree111Likes
Kyosho MP9E Thread
    Hide Wikipost
Old 11-25-2016, 05:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho MP9E Thread
Last edit by: tobamiester
Kyosho MP9e Wiki.
Mp9e TKI4 Manual
Print Wikipost
Old 03-14-2015, 06:45 PM
  #2521
Originally Posted by wreckya View Post
Started my build last night, surprised there's not a washer between the o-ring and shaft in the diffs. How well does the o-rings hold up? Is the grub screw in the diff cup used as a bleeder? If so does anyone really use it? And how would u put new oil in it? with a syringe?
grub screw is so you can get the cross pin in. Install the cross pin then put the grub screw in before filling the diff with oil. Just tighten it until it's flush with the inside of the diff case.
I haven't had any problems with the o-rings. I replace them maybe once a season.
stwallac2007 is offline
Old 03-14-2015, 06:46 PM
  #2522
tobamiester's Avatar
Trader Rating: 344 (100%+)
O-rings last good in my experience.
Not 100% on the purpose of the grub screw. I've used it to slide the pin from the outdrive easier..I guess yes it could be used for bleeding when your putting to diff together, so excess oils exits...
tobamiester is offline
Old 03-15-2015, 07:38 AM
  #2523
1/8 IC Fan's Avatar
Trader Rating: 99 (100%+)
Speaking of Fioroni they make a sweet steering top plate and use to only make it in blue which is not my color but know I see they make it in gunmetal color. If I could find there ergal towers in that gunmetal I would consider a set of those.
There were very few of those Hard Anodized Towers made, their regular is the standard anodized blue and black, with very select few parts getting the Hard Anodized treatment. It seemed as though with the MP7.5 there were more Blue Fioroni parts, and with the MP777 there were more Black and now with MP9 they are back to Blue.
1/8 IC Fan is offline
Old 03-15-2015, 11:10 AM
  #2524
wreckya's Avatar
So I read in here to put a shim behind the pinion gear in the diff? Is it needed period or based off the ring and pinion mesh? Someone posted 0.1mm what about id and od size anyone have washer sz or part #? Also shims on rear inner hinge pin on each side of A arm sz or part #? Thanks for the help guys.
wreckya is offline
Old 03-15-2015, 11:15 AM
  #2525
wreckya's Avatar
I run Tekin on my Tekno sct and Orion on my HB. Was thinking of tryin a Orion R8.1 pro and the 690 1900kv motor, anyone else running this combo? Any issues anyone own it and the Tekin and can compare them? I think the R8.1 is a smaller footprint but not sure of height w bodies? Thanks in advance.
wreckya is offline
Old 03-19-2015, 12:41 AM
  #2526
wreckya's Avatar
Anyone?
wreckya is offline
Old 03-19-2015, 12:52 AM
  #2527
wreckya's Avatar
Someone makes a flexible body post, not sure if it was Mugen or who it was but would really like to pick one up.
wreckya is offline
Old 03-19-2015, 01:11 PM
  #2528
1/8 IC Fan's Avatar
Anyone?
Your good going with leaving a "Two Sheet" gap as stated in the manual on the Pinion between the case and the Universal. Its basically the thickness of two sheets of paper. As long as you have the 0.15mm shim on the diff (ring side) you should be ok. You may just have to recheck your universal gap to case every now and then.
Old 03-19-2015, 01:19 PM
  #2529
wreckya's Avatar
Ok it sounds like your saying I only need this shim if I'm using a shim over the outdrive between the bearing and diff case also? Is that what your saying? Or do I shim like in the pic regardless of having to shim between the outdrive bearing and diff case?
wreckya is offline
Old 03-19-2015, 01:21 PM
  #2530
wreckya's Avatar
Anyone know where I can find the flexible body mounts? I think there aluminum on top with rubber underneath.
wreckya is offline
Old 03-23-2015, 04:46 PM
  #2531
Trader Rating: 22 (100%+)
Does anyone have any new, good indoor setups for a regular indoor sized track?
I use Tebo setups but he doesn't really have much for indoor (obviously not too common)
jonasm48 is offline
Old 03-24-2015, 02:40 PM
  #2532
They are made by a company called 6mik, from Europe I believe.
MattPR8 is offline
Old 03-24-2015, 03:08 PM
  #2533
You should watch Tebo's tech tip videos on building and shimming MP9 diffs. He has a lot of very useful info in them that will answer all of your questions.
http://jtprc.com/tech-tip-videos/
Derek_Wood is offline
Old 03-24-2015, 07:18 PM
  #2534
wreckya's Avatar
Awesome thanks man.
wreckya is offline
Old 03-24-2015, 07:19 PM
  #2535
wreckya's Avatar
Thank u sir!!
wreckya is offline
