Pictures of a Losi XXX-SCT Short Course Truck.
#62
how did you mount the nerfs
#64
Trader Rating: 19 (100%+)
Feeling a little slow, I is a little slow,
the way he broke it up, and used ych, instead of ik, threw me for a loop.
I should have known Mark would throw something like that at me, just to make me look stupid, he's just trying to get back at me, because I usually beat him on the track.
I've got about $65. in new Associated parts, $40. in new tires, and $30. in a new body.
At first I tried to make some like what comes on the SC10, by trying to cast some out of Epoxy,using clay as a mold, but could not get the Epoxy to stick well enough, probably because I didn't wait long enough for the Epoxy to cure. You can see how I tried to do it, in these two pictures.
My next thought was to drill holes in the side of the chassis, but after thinking about it for awhile, I really didn't want to do that, so I decided to try to just use that real Strong 3M outdoor double stick tape, as you can see in this picture.
#65
I might try a nitro version, my friend has a whole bunch of xxx-nts and parts that I cna pretty much get for nothing.
I was thinking of extending the from just in front of the gas tank and leaving most of the weight in the rear.
#66
#67
first I need to get the doner trucks
#69
They are giving away gas trucks on ebay. If you spent just a little bit of money and converted it to an SCT, it would all a suddon be the talk. Cheaper than crap to convert, and you end up with something that is the going thing right now.
Wheels/tires, and a body is the bulk of your cost.
#70
What is the whelebase on a XXX-NT? I kow it is slightly variable for tuning purposes. Is it close enough to the SC Spec???
#72
ok i am really looking in to this but i want to make it legal to race, could you expand on the way you made it less wide and if possible tell me which rear cvds you used. i am doing this to a XXX-T MF1 and when i took off the rear wheel the axel looked like the top one in your picture but with longer threads.
also after looking at the truck for a couple min i think i may have come up with an easy way to make the car longer by making a new T plate out of aluminum and a brace on top. what do you think?
thanks,
Thomas.
thanks,
Thomas.
