Why no 50c saddle packs? >
Old 09-25-2009, 02:13 AM
  #16
SwisströM's Avatar
Originally Posted by big greg View Post
i dont think you would notice the difference in those vs the 30c, i have the ip 6000 30c's shoot if ya need more then 180 amps you must be running a 1/8 scale, even those only need 100 amps
That's different.
1/8 require 100Amps @ 14.8V, or 1480Watt
100Amps @ 7.4V are only 740Watt (more than enough for a 1/10 buggy with a 4.5+ motor, but surely not enough for a 1/8 motor).
SwisströM is offline
Old 09-25-2009, 02:22 AM
  #17
big greg's Avatar
Trader Rating: 119 (99%+)
Originally Posted by SwisströM View Post
That's different.
amps are amps, i was saying an 1/8 vehicle will pull more then a 1/10 anyday
big greg is offline
Old 09-25-2009, 02:32 AM
  #18
SwisströM's Avatar
yes, but Ampere is not a measure of power. You can't simply compare them at different voltages.
A 1/10 can pull more Amps than a 1/8.
A 1/12 pan car with 1S lipo and a high-kv motor pulls more Amps than a 1/8.
Old 09-25-2009, 04:08 AM
  #19
TRF415boy's Avatar
Team Orion are releasing a 45C / 4500 saddle.
They'll be available in a few days.
TRF415boy is offline
Old 09-25-2009, 07:30 PM
  #20
lookieaefanboi's Avatar
Trader Rating: 37 (100%+)
Any idea how much? Where can I get one? There is no info on the orion site so have you seen a preview/review somewhere?
Cheers
Luke
lookieaefanboi is offline
Old 09-26-2009, 07:31 AM
  #21
rcman1993's Avatar
Trader Rating: 33 (100%+)
just change to a different motor if you dont have enough power. you wont really need to use the 35c-40c on mod, only stock. and with a 4wd, its mod so just change motor. the cell is too wide, it is pretty much a square so you wouldnt be able to fit it anywhere exept in a 1/12 scale car like it was designed to do. 1/12 uses 4 cell or 1 cell lipo so it wont work out.
rcman1993 is offline
Old 09-26-2009, 01:36 PM
  #22
TRF415boy's Avatar
Cheers
Luke
Can't say when in the US or how much, but they've arrived to the distributor in europe and are being despatched to the shops. Agressive pricing I was told.
Old 09-26-2009, 06:40 PM
  #23
Don't really care about US availability as I am in australia I tend to find pricing in the EU very expensive, am I looking at the wrong shops? If you can find out what shops they are going to it would be much appreciated
Old 09-26-2009, 08:52 PM
  #24
astroboy403's Avatar
what you also need to remember is what you increase the volts by two the amps go down. so a 1 cell lipo will need a higher "C" rating than a 2 cell.
astroboy403 is offline
Old 09-26-2009, 09:50 PM
  #25
Why not more 50C packs
Because some companies know more mugs buy cheap cells reabelled with big numbers
There is no standardised way of establishing the C-rate and it is prostituted too often.
There is a way to do it - by stating the Internal Resistance of the cell at a given temperature and then the watts (heat) per gram at continuous max - They should also state the level of match of the cells.
Or you look for independent testing and always check the constant rating is 50% of the peak - not 80 or 90% - the latter means its overated on the constant spec
There are very few makers who sell packs at an honest rating the best packs I have ever tested are the Thunder Power 40/80's hardpacks- they have half the resistance of the V2 Extremes and 1/3 less than the 30/60C ProPowers.
Fastelectrics is offline
Old 09-26-2009, 10:17 PM
  #26
Only true for an equal power comparison, which requires a corresponding change in the load/motor resistance.
From a practical RC angle, 1 cell generally means a relatively light pan car, which has different power requirements than typical 2 cell RC vehicles such as an off road 4wd that I believe is being discussed.
Dave H is offline
