Old 02-02-2004, 07:32 PM   #1
Angry how do i get this off!!!!
how do i get the flywheel off my mach 15 engine from a team losi xxx-nt sport?
savage13579 is offline   Reply With Quote
Old 02-02-2004, 10:13 PM   #2
xxxtracer32's Avatar
is it stuck on?
xxxtracer32 is offline   Reply With Quote
Old 02-02-2004, 11:02 PM   #3
warpig's Avatar
take a mallet and lightly tap around the whole area around the flywheel.. not too hard.. and not in just one spot.. it will eventually come off.. do not pry off
warpig is offline   Reply With Quote
Old 02-02-2004, 11:08 PM   #4
Send a message via AIM to Gped0124 Send a message via Yahoo to Gped0124
The sport uses a threaded on Flywheel, tap it with a mallet will not do anything. You have to lock the crankshaft and use some channel locks to unthread it, regular left loosey thread.
Gped0124 is offline   Reply With Quote
Old 02-02-2004, 11:11 PM   #5
even after taking off the nut the fly wheel can stil be stuck on the cone washer under, the mallet trick will work or ive used the small battery terminal puller for full sized cars,.
Old 02-02-2004, 11:15 PM   #6
warpig's Avatar
yes.. you can use a puller also.. you need to purchase an ofna flywheel wrench.. or carefully hold it with channel locks and a towel... and take the nut off..
Old 02-02-2004, 11:17 PM   #7
warpig's Avatar
ok.. I think I understand now.. I've never seen a threaded on flywheel.. are you sure.. if it is true.. use some after run oil.. take out the glow plug.. look in the exhaust port and make sure the piston is close.. not at... top dead center.. and fill the combustion chamber with the after run oil.. then replace the plug.. you are now hydrolocked and can apply a wrench to the crank.. I use this method when I don't have a flywheel wrench available..
Old 02-02-2004, 11:19 PM   #8
warpig's Avatar
how does that wonderful engine run that losi hooked you up with anyway?? haha... j/k
Old 02-03-2004, 01:31 PM   #9
ok i got if off by using hte mallet thing after unthreading hte pilot shaft with an allan wrench (for all the other losi ppl who can't get it off) the engien is great but im hooking it up with an os cvx 12 engien that was ported
Old 02-03-2004, 02:09 PM   #10
warpig's Avatar
novarossi is the way to go... IMO... ballistic and very reliable
