HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 03-10-2010, 08:53 AM
  #1276
bmitchell373's Avatar
I ordered 2 sets of those DE skids. I cant wait to get some wear on them and see how they hold up. The track here is a chassis eater.
bmitchell373 is offline
Old 03-10-2010, 08:55 AM
  #1277
Originally Posted by HYDE16 View Post
For the D8 body, there is no gap if the body fits on the chassis perfectly (smaller battery). With my battery I have a gap on one side on the front driver's side corner.
For the MP9 body, there is an even gap (front to back) of about a quarter inch on both sides. Should I be concered with the gap?
The less gap the cleaner the inside of the buggy will stay. Velcro around the edges or single sided foam tape. Either would be good.
Old 03-10-2010, 09:00 AM
  #1278
HYDE16's Avatar
So they come in a pack of 3, are these only for the rear of the chassis?
http://www.deracing.net/sales.htm#hbd8
Are there skid plates for the front at all? Just the front bumpskid plate?
http://www.deracing.net/sales.htm#hbd8_front
HYDE16 is offline
Old 03-10-2010, 09:33 AM
  #1279
Just those 2 but thats all you need. The front for if you nose dive to much and the rear for slapping down after big jumps.
See where the main wear is, thats what the skid plates over. The front could be a little longer, but after its on it should hit before the chassis does.
Old 03-10-2010, 11:19 AM
  #1280
Trader Rating: 44 (100%+)
Getting the stock front bumper off seemed kind of tricky, but the replacement DE unit mounts the same. It gets pinched between the chassis and bulkhead when you tighten the screws.
Here is the post with the photos of the skids mounted.
http://www.rctech.net/forum/7060455-post1003.html
Here is the one with the photos of the street tires.
http://www.rctech.net/forum/7060460-post1004.html
ben
armourbl is offline
Old 03-10-2010, 11:40 AM
  #1281
HYDE16's Avatar
That was a huge help!
I just ordered the tapered outer hinge pins and the skid plates.
HYDE16 is offline
Old 03-10-2010, 02:36 PM
  #1282
Does anyone know if the screws in the chassi are stainless? If not, can you buy a kit of stainless screws?
Limpan is offline
Old 03-10-2010, 03:01 PM
  #1283
Nope, not stainless. Haven't heard of a kit, give it some time. Either that, or make a list and head to the Ace Hardware and get as many replacement stainless as you can find. They have a pretty good selection, just pricey at about $.50 each.
ben
armourbl is offline
Old 03-10-2010, 03:05 PM
  #1284
ben
Oh.
A friend of mine bought a kit of stainless screws for his RC8e. Any chance the same screws will fit the Vorza?
Limpan is offline
Old 03-10-2010, 03:07 PM
  #1285
Oh.
More likely that a D8 kit would work, but it wouldn't likely have all of the screws.
ben
armourbl is offline
Old 03-10-2010, 03:47 PM
  #1286
outtafocus's Avatar
You don't want stainless screws. They are weak and will strip out or break long before a standard steel screw would. They are also no lighter than the standard.
The only screw kit to buy is that made by Tonys Screws.
He currently doesn't make a Vorza specific screw kit, but Im sure its on the way, not many cars that he doesn't do a kit for.
There is a D8 kit which will give you the majority of screws.
http://www.tonysscrews.com/product.s...&categoryId=61
You could also look at Lunsfords Titanium screws, very expensive but awesome, or Mugen makes some Ti screws also. Super light weight.
I have been putting DE skids on my cars for a while now. I wouldnt run a car with out them.
My Vorza chassis arrived today, now just gotta wait for the rest to come available.
But I want it now.
outtafocus is offline
Old 03-10-2010, 04:05 PM
  #1287
I use some Stainless on the top of some cars for a BLING factor, but noting that requires alot of torque.
Old 03-10-2010, 04:43 PM
  #1288
danulmer18's Avatar
Has anyone tried the Xtreme Racing D8 Carbon fiber mud guards?
In the past I have not paid much attention to the skid guard discussion on this thread.
Can someone post the available options for our Vorzas?
Also, is anyone interested in seeing my updated setup sheet chart based on the latest Ve8 and D8 setup sheets found on the web?
I am interested in the setup sheets! Post away!
danulmer18 is offline
Old 03-10-2010, 06:03 PM
  #1289
Here are my home made mud guards. I think they turned out pretty good. Thanks to Mr. Mya for posting templates. I used Plexiglass, traced it out from the template, then a 561 bit on a Dremel to rough cut them out. I then used a sanding drum on the Dremel to sand them evenly to my trace lines, then hand sanded the edges to finish them.
I drilled the holes using a 1/8th bit in my dremel, and countersunk the hole by the hinge pin since the screw is short and the Plexiglass was thick.
Also attached are picture now of my chassis with the DE Racing skids. All of those scratches are from the track, not bashing. I have only bashed it at the park on grass. Arizona has rocky soil unfortunately. I walked the track several time to pick up rocks, and this is still the result.
ben
Attached Thumbnails HPI Vorza Flux 1/8 E-Buggy Thread-p1010222.jpg   HPI Vorza Flux 1/8 E-Buggy Thread-p1010223.jpg   HPI Vorza Flux 1/8 E-Buggy Thread-p1010224.jpg
armourbl is offline
Old 03-10-2010, 08:37 PM
  #1290
ben
Those are pretty think, Not to heavy? Only other thing would be not having any flex it might have to much drag. Gota test em and give a report im really curious. They look Sweet tho.
