HPI Vorza Flux 1/8 E-Buggy Thread
#676
Ryan,
March is coming! I see a test date coming soon! So how does your weekends look for this month?
I will be the only guy without a Vorza so I hope you guys wont hold it against me. LOL
I will have my Losi. But this will be good for you all! If you can beat my Losi then your car will be dialed. LOL
#677
Ha! Sunday the 21st looks good for me pending we don't have a snow covered track.
I've been trying to get a "Vorza Meet" setup for some of the owners in Northern NJ.
#678
http://www.castlecreations.com/image...d-Link-Car.jpg
#679
Has anyone given any thought to the D-Box upgrade?
#80588 ADJUSTABLE STABILITY CONTROL SYSTEM / DRIFT ASSIST
Click here for a video of the HPI D-Box Drift Assist in action
I know they show this for street / carpet racers but do you think it would work rounding out the turns on dirt tracks? They have it listed as an option part under the Vorza site.
#680
I know people who run it in their baja 5b/t.It works.It is also illegal on tracks.Basicly if you didnt know your dbox plugs into the steering channel and your steering servo plugs into the dbox.When the back of your vehicle slides either right or left the box counters the steering for you so you cant spin out.You can set the dbox for sensitivity.There are you tube videos on it.Me personally can think of better things to spend 100 dollars on.It would however fit inside the vorzas radio box with my futaba 2.4ghz receiver so who would know you have it.
#681
It might make bashing more fun. You could always take it off for races. I don't know....
ben
ben
#682
Hey guy's i happened to stumble across this for $27 , may be comparible to the d box and allot cheaper http://hobbyking.com/hobbyking/store...dProduct=10314
#683
First, I want to say that this is the best thread I have ever seen. Great information sharing and focus. I recieved my Vorza on the 6th, but haven't been able to even open the box till tonight (work preventing).
I have only a couple of current questions: (1) Is the quote below still the best initial setup (for medium size, technical track); (2) what is everyone using for the initial gearing (running 2 x 2s)?; (3) which is the best fit for the replacing of the hinge pins (front and rear)? the Hotbodies 66800 identified eariler in this thread? and are they to be used in both the front and rear?
Again, I want to thank everyone posting to this thread and will post any/all of my findings/results Sunday (if we race down here in Georgia).
So right now it seems we're all hovering around this setup
DIFFS: Front 5,000 / Center 5,000 / Rear 2,000-5,000
SPRINGS: Front White 60mm / Rear Yellow 68mm
SHOCK DROOP: Front 98mm / Rear 100mm
SHOCK OIL: Front 35wt / Rear 45wt
RIDE HEIGHT: Front 27-28mm / 28-29mm
Has anyone experimented with heavier shock oil weights?
Specifically in the rear to prevent bottoming out?
The longer rear yellow 68mm springs should help but it seems we may need to go heavier than 45wt.
#684
I wanted to see what that HPI Drift Assist BOX was worth "on the streets", but €120 ($160) is a little to much to waste - if I didn't like it.
Well, turns out that that HPI Box is a re-branded Futaba G190 Micro Piezo Gyro G-190. And they sell for about €38 ($52) on Ebay.
Works really well in my Sprint, haven't tried it in my Savage or Vorza yet.
#685
#686
Stocker the HPI hinge pins do work but they arent the best fit. They are alittle long so you will have to come up with some kind of washers or something to make them fit better. M2C racing makes I think a really nice set of 4 I belive for the D8 which work, I think they cost $10. They use tool steel which is awesome quality material, and Mugen the ones for the MBX5 and 6 buggy also fit. They both fit perfectly and are much better quality then the HPI ones but I have some of all of them they all do the job but the 2 others are better and will last lots longer before needing replaced.
#688
I just ordered the icharger 106b+.Anyone know how long it normally takes to get the items from Hobbyking?
#690
Stoker
That set up you posted from Hyde16 is a great start. You can fine tune from there. You may find heavier oil and springs in the rear help prevent chassis "slapping", but weather conditions will vary for all of us.
