HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree16Likes
Old 02-03-2010, 11:05 AM
  #541
Trader Rating: 19 (100%+)
Muge0124
malik is offline
Old 02-03-2010, 12:53 PM
  #542
HYDE16's Avatar
Iím still a little fuzzy on what these shafts replace exactly.
From the parts explosion diagram in the Vorza manual it seems like they replace:
2 x 67415 Suspension Pin 4x71mm Silver (Front/Inner)
2 x 67417 Suspension Shaft (Rear/Inner)
What about the shorter shafts which hold the wheel hubs? Do those back out and are there shafts with nuts to replace them?
2 x 67416 Suspension Pin 3x43mm Silver (Front/Outer)
2 x 67418 Suspension Shaft (Rear/Outer)
Found them on AMainHobbies for $14.25 for 2:
Mugen Option Rear Lower Suspension Shaft w/Nuts (2) [MUGE0124]
HYDE16 is offline
Old 02-03-2010, 01:07 PM
  #543
I thought that the Vorza like the D8, D8T, and Ve8 all used captured pins. Why would you want to replace those with the Mugen pins?
I could understand doing that if the hinge pins use E-clips since most people don't know how to keep those on but to replace perfectly good captured pins, really?
I've raced Kyosho buggies for years with E-clips and never lost a hinge pin except for crash damage (bent). How do you manage to lose a captured one except if you forget to replace the capture screw or the arm breaks.
AreCee is offline
Old 02-03-2010, 05:19 PM
  #544
*BBB*'s Avatar
Could any of you guys give me a quick list of parts from the D8 that WONT fit the Vorza? Like the chasis, shock tower, knuckles etc. Im supposed to get one tom and want to stock up on some spare parts..
Thanks!
*BBB* is offline
Old 02-03-2010, 05:37 PM
  #545
danulmer18's Avatar
the vorza hingepins arn't captured in the sence that they have nuts threaded onto the ends of the pins(like the mugen). They arn't e clips either. They slide in and are held in place with tiny screws and washers threaded into the a arm. This works ok for the inner ones as they are seated in alloy blocks but I threw an outer rear one the other day. It just pulled through the plastic of the arm. The mugen outer pins would prevent this. I will get some, I think they will be a good investment.
danulmer18 is offline
Old 02-03-2010, 06:09 PM
  #546
danulmer18 is right. The inner hinge pins are not the problem. It's the outer pins. The outer shafts are captured by screws and the hinge pins are a little too short. On a good crash, force on the wheel and hub pull on the pin and it can pull out from the arm.
Fastenough is offline
Old 02-03-2010, 06:29 PM
  #547
HYDE16's Avatar
So these work with the pins/shafts which hold the wheel hubs?
Please verify that 4 of these (2 sets) would replace:
HYDE16 is offline
Old 02-03-2010, 07:17 PM
  #548
You're kidding, aren't you. If you crash that hard to "pull" the pin you have more damage than a loose pin. Honestly, this is how all the top line buggies and truggies are set up now, from Kyosho to Mugen to Xray to AE. They all use a similar captured pin method since so many people were crying about e-clips.
But hey, it's your buggy and you do have the right to do what you want to it.
AreCee is offline
Old 02-03-2010, 07:20 PM
  #549
Hyde16
These will work too.
http://www.hotbodiesonline.com/piw.p...n&partNo=66800
They're in stock on HB's website and cheaper. These are what I got. Only one issue - They're a little long, I think they're for their old truggy and spaced to accept mud guards. I had to use a spacer before the nut to take some slack.
I used them to replace 67418 and 67416
Old 02-03-2010, 07:26 PM
  #550
AreCee - Not true.
Check out Mugen's link. If you look at the magnified photos, Mugen uses a pin and nut like we're talking about
Old 02-03-2010, 07:27 PM
  #551
Sorry, here's the link
http://www.mugenracing.com/index_mbx6.html
Old 02-03-2010, 07:36 PM
  #552
Arecee
XRay uses a screw and nut too.
http://www.teamxray.com/teamxray/new...079a58301d110b
Old 02-03-2010, 07:42 PM
  #553
Arecee
OK whatever!
AreCee is offline
Old 02-03-2010, 09:08 PM
  #554
Thanks guys for the info.I looked at the mesh and it is too tight.Also quick question.When I got the Vorza I immediately took ou the radio receiver and converted to a 2.4 Fasst system minus servo which I'll get to next.I plugged in a battery and tested it out.Worked fine.I then noticed at work while I was reading the manual.it says you have to program the esc for the first time.I figured because It worked when I did the radio swap it was programmed.Is this correct.Also what would you say the best servo I can install is under 150.00.thanks guys in advance.
Brian.
bnangle is offline
Old 02-03-2010, 09:50 PM
  #555
danulmer18's Avatar
Arecee believe it or not it happened to me pretty easily with no other damage and from a small crash as far that crashes go. Definitly a good upgrade to go to the fully captured ones.
