HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 12-14-2010, 08:37 PM
  #2581
Registered User
Originally Posted by bigben1165 View Post
i cant imagine needing more than 5000mah, you can prolly run for 25 min with that.
I use (2) SMC Sport-Max LiPo 7.4V 4500mAh 28HC Deans
They're ROAR approaved for racing, and I get great run times out of them. I plan on picking up another set in the very near future.
RCCobra is offline
Old 12-15-2010, 06:46 AM
  #2582
bigben1165's Avatar
Originally Posted by Glenwyatt View Post
That's what I'll do then...
Thanks for the help
One other question- Has anyone run on 30C batteries before? Will they hold up or am I asking for trouble?
if you are running over 4000mah and 30C you should be gold. i put a voltmeter on the vorza and with the 2650kv and 6s full power it drew about 125amps. 4000mah at 30C should be good for 120amps constant and 150amps burst.
bigben1165 is offline
Old 12-15-2010, 08:14 AM
  #2583
I ended up ordering some 5000mah 30c 2s batteries.
Thanks guys
Glenwyatt is offline
Old 12-16-2010, 02:26 AM
  #2584
Ascari-A10's Avatar
a little noobish question here.. im thinking of mounting a fan above my motor with the stock fan mount above it.. do i connect it to my receiver or an external battery source?
Ascari-A10 is offline
Old 12-16-2010, 06:35 AM
  #2585
bigben1165's Avatar
you can connect it to your receiver if you have an open channel or use a Y connector with another receiver plug.
Old 12-16-2010, 06:43 AM
  #2586
bigben1165's Avatar
Thanks guys
you will be able to pull 150amps constant with those, but you never will get that high. i bet they barely even get warm. i keep track of how many charges are on my packs. im also a cell phone junkie. i take a picture of each pack and add them to my Contacts on my phone. i go in and edit them entry with each time i charge the pack. anytime i can just look at my contacts and see how many times i have used each pack. here are my findings so far:
thunderpower 4200 mah, 20C, 10s - 5 cycles, then puffed ($400 pack!)
Flightpower - 3600 mah, 25C, 10s - 155 cycles, down to about 90%
Tanic Packs - 4250 mah, 25C, 10s - 98 cycles, still like new
Hyperion - 4200mah, 35C, 10s - 125 cycles, died when my Logo 700 tried to kill me
Venom - 3600, 30C, 6s - 15 cycles, still getting stronger!
Old 12-16-2010, 07:01 AM
  #2587
Ascari-A10's Avatar
any channel will be fine? cos i dont use my 4pk 4th channel will be ok right?
Old 12-16-2010, 08:36 AM
  #2588
bigben1165's Avatar
yup, any channel. the servo wire/connector is not rated for more than 5 amps so the only time i wouldnt piggyback 2 connectors is with a high power digital servo.
Old 12-16-2010, 08:41 AM
  #2589
Ascari-A10's Avatar
thanks ben.. cheers..
Old 12-16-2010, 02:47 PM
  #2590
bigben1165's Avatar
anytime buddy, glad i can help. let me know if you need anything else!
Old 12-16-2010, 05:54 PM
  #2591
Ascari-A10's Avatar
yep i need the 112mm shocks, proline tires, 2650kv motor, mp9 cover.. thanks! LOL!!! kidding..
Old 12-16-2010, 07:18 PM
  #2592
bigben1165's Avatar
well done
Old 12-16-2010, 11:00 PM
  #2593
Suspended
Trader Rating: 132 (100%+)
Alright, someone help me out....Picked up an Airtronics M11, but I can not get it to work with the Vorza. I can get it to work with everything backwards lol, but can not get it to work normal.
badaml is offline
Old 12-16-2010, 11:12 PM
  #2594
does anyboy see that the vorza has the same parts as the d8 mean the wing is the same ant the shock tower is the same exept the front tower is plastic
racerdork is offline
Old 12-17-2010, 01:26 AM
  #2595
Suspended
Well, finally got it Apparently the esc was not finding neutral. So......I moved the sub trim for the throttle up a little bit, then all was good. Little bit of a PITA to set the failsafe after that, but I am all set now.. Vorza with an 18t pinion on a 4s 30c 4500 lipo with an Airtronics M11 with spectrum pro, and a KO Propo digital servo at 222 oz.
badaml is offline
