HPI Vorza Flux 1/8 E-Buggy Thread
#2461
Anyone know why the rear center shaft part seems to be listed as "discontinued" everywhere? (... and "out of stock" on the hpi site).
It figures this is the first thing I broke...
HBC8069 Center Shaft 90mm Lightning Series
EDIT: Would this generic dogbone from Ofna work instead? http://www3.towerhobbies.com/cgi-bin...?&I=LXHMG4&P=7
#67178 - WCE rear Center Driveshaft
#103691 – Regular universal Rear Driveshaft
the 4x dogbones(wheels) are 90mm and listed as HBC8069 in the manual.
though if you need dogbones go to:
http://www.rctech.net/forum/r-c-item...based-car.html
and buy the used universal ones he's got listed under the car, awsome price.
iwas gonna buy them but got a pair free by chance.
and those shafts from tower you listed are two different legths, one is 86mm, and one is 90mm they come as a pair. so don't buy that set if you need dogbones(for the wheel shafts)
#2462
that's not the proper part. if i remember the rear center shaft is around 110mm part #103665
I'm guessing from your mail that these can be replaced with universals... but which ones? (I'll take a look at that link, thanks!).
#2463
i listed two versions of center rear driveshafts (they go between the center dif and the rear dif) , the WCE is the "world championship editions" and the regular is the "high efficiancy adn durabilty" universal shaft.
with both you replace the rear shaft retainer and shaft with the universal.
the ones in the link are to replace your dogbones. (they go between your rear dif and your wheels)
they are completely different applications.
i was confused by what you actually needed by your first post. since the length you were interested in was 90mm(dogbones) but you used the words "rear center driveshaft" which is 110mm(normal) 105mm(universal)
#2464
all the shafts can be replaced with universals.
Ok... bear with me here then as I try to learn the terminology correctly. So what I'm looking for are universal drive shafts for the rear to the wheels. Aren't the ones listed in the add you linked too long?
So what exactly does CVD stand for? (sorry for the stupid questions... just trying to sort it out since the manual isn't particularly clear other than for listing part numbers!).
#2465
and they'll fit perfectly!
.. they're a bit longer 91 or 92mm(HPI changed the design after a while) to prevent "pop outs".(when the "dogbone" end.. looks like the end of a dog's bone slips out of the "retainer".. or "the thing it goes into") .. the measurement i asked for in the thread is from a different point than usually measured from, hence the longer length listed. they are direct replacements for the stock ones.
Constant Velocity Joint CVDs have a barrel, a pin and set-screw to hold it together
and a "Universal" Joint uses an actual universal + joint at the end. this + is made using a internal middle piece and two pins that crosseach other..
"CVD" and "Universal" are sometimes (i did it) used interchangably to describe both CVD and universal CVD types of shafts.
.. they're both very similar in design and both perform the same job, just one is better and more efficiently than the other one.
"CVD" stands for "Constant Velocity Driveshaft" and actual CVDs are best used as axles to drive the wheels ,as they have be able to do various angle changes as the suspension goes up and down while you drive over bumps.
and "Universal" jointed driveshafts are best used as center driveshafts because they stay stationary and don't move up and down..
the ones in the ad (link) are CVD and are properly suited to be used to replace the wheel dogbones... normally they're about $30 each ($60 a pair) or more depending on what brand you buy.
Cheers, EH!
Phil
#2466
yes the ones i linked are for the wheels.
Cheers, EH!
Phil
Cheers, EH!
Phil
At this point I'm just trying to find a reasonable option that I can get quickly... since this messed up my weekend plans *grin*. (That's what I get for going a little too crazy with my new 6s setup and sliding side first into a sidewalk).
It is pretty annoying though that you can't find the stock part anywhere (especially since its the cheapest option).
#2467
Regarding the option parts... would the following be appropriate for the rear diff to wheel shaft?
http://www3.towerhobbies.com/cgi-bin...7518&search=Go
(Part 67518, Universal Drive Shaft Set)... I'm assuming this is a CVD drive shaft.
I'm having trouble distinguishing which drive shaft each part is intended for... there are two down the center, and one going to each wheel right (or am I missing something obvious)?
Also... with this type of part, if you replace one side, is it important to replace the opposite side as well for balance, or does it not matter?
EDIT: ... so 67518 is stock on the fronts... can the same part be used in the rear (is that why it is listed as optional in the manual as well as in the stock parts list?).
Thanks again... having this buggy has been a great re-education for me in all things RC (I was out of the hobby for quite some time, and am LOVING this model!).
#2468
http://www.hpiracing.com/products/en/67518/
YES, if you change one side, you have to change the other side to CVD... ok you don't have to, but the car will not steer evenly through corners. you'll get over steer in one direction and under steer in the other.. the car may be out of balance mid -air aswell.. but you could drive with one side cvd and the other dogbone.
for reference:
this is the WCE version wheel axil CVD drive shaft
http://www.hpiracing.com/products/en/67177/
this is the rear center CVD shaft
http://www.hpiracing.com/products/en/103691/
the WCE version rear center CVD shaft
http://www.hpiracing.com/products/en/67178/
the WCE version rear center CVD shaft ONLY
http://www.hpiracing.com/products/en/67170/
this is the front center CVD shaft
http://www.hpiracing.com/products/en/67217/
the WCE version Front center CVD shaft
http://www.hpiracing.com/products/en/67179/
the WCE version Front center CVD shaft ONLY
http://www.hpiracing.com/products/en/67171/
For reference this is what actual NON-CVD UNIVERSAL joints look like
http://www.google.com/images?q=unive...w=1276&bih=805
you can see the difference, a CVD likes like a ball end going into a cup, with a single pin throught it, where a universal has two opposite pieces around a middle + piece with TWO pins joining it all together.
NON-CVD universal joints don't have as great of a range of motion as CVD's do.. at great angles they'll bind up, wear out, and then break, because the shaft hits the middle piece.
#2470
Would you guys recommend the Vorza for someone who just wants to have fun with a 1/8 electric buggy? Nothing serious.
#2471
Yup, my buddy's got one. Durable platform, cheap parts, and with a few minor tweaks, you can be competitive racing it.
#2472
also the vorza is NOT durable at all. i've been very disapointed with it. with most of the parts on it being either Losi, Redcat, or machined myself.
the most durable cars out there are team associated, mugen, kyosho and tamyia. with a highlight on the tamiya TRF801X/T.. they're incredibly tough.
#2473
can you link some info about the "tweaks" to make it competitive? i'm mostly into bashing, but will be taking it to a track next summer. but bash on it this winter.
#2474
my buggy seems pretty durable. i broke a wheel knuckle...but i hit a curb sideways at 40mph rounding a corner. i had a D8T before my vorza. pretty much the same vehicle, just a little taller and longer and wider. the HPI savage has the same electronics as the vorza and is a serious basher if thats what you are after. the savage can even be modded a little to be competitive for racing...assuming you can find somewhere to race a monster truck. hahahhahaa
#2475
If you're just looking to bash around the neighbourhood it should be noted that Truggy's are easier to drive, more durable, handle shock and abuse better, go through grass better than buggies.
