HPI Vorza Flux 1/8 E-Buggy Thread
#2342
http://www.castlecreations.com/produ...le_motors.html
#2344
hey guys
i got the elite rc mount, you were right it looks like a real quality piece! one question before i instal it: i switched gearing to 21 pinion and 44 spur, will i still need to shim the assembly up? or will the motor now mount far enough away from the spur to allow clearance without shimming?
just wanted to get your thoughts before i spend time machining/making some shims when i really dont need to. Really dont want to grind down the alum nubs on the motor.
thanks guys
BB
thanks guys
BB
#2345
hey guys
thanks guys
BB
thanks guys
BB
#2347
Yep. I'm not sure how thick you'll have to make the risers. Do you have any machining equipment? I don't, so I've been trying to think of what I can use... any ideas?
#2348
Thats what I did took around 10 mins to make, job done!!!!
#2349
i just raised all four mounts using 3mm thick washers. used the original screws and is very tight fit. kept me from having to machine anything. may have to grind away a little of the servo mount i think the front center dogbone may rub now. rear center drive dog has plenty off clearance. the motor has at least 2mm of chassis clearance.
#2351
Hi Chaps
First off thanks for all your input in this thread - been great reading !!!
Had a Vorza for a few weeks - and one thing i've noticed is that you must check the build on your car when you get it.
The front Inner Hinge brace (rear) was loose on mine - i only noticed it when the lower arms kept popping out.
By then it was too late the bolts had stripped the thread in the front diff with normal bashing.
So far i've tried to fit a longer bolt but that didn't last too long - next up is to araldite the bolt into the diff casing, but i don't expect that to last long either.
I may have to get a new diff casing .. Eeeek.
I have played with the idea of using some bolts and drilling some vertical holes through the rear brace and chassis to stop and rearward movement in a crash
Anyone else had a any issues with this - other than that the Vorza is a blast
#2352
Quick battery question.
Normally I run 2x2S=4S or 2x3S=6S. Well 4S is not quite enough power and 6S is way to much power. I'm running a 19T pinion gear.
Can I run a 2S+3S=5S or will they discharge uneven/out of balance?
I would only do it a few times to see if it is worth it for me to invest $$$ in a 5S battery.
P.S. Both the 2S and 3S=5S test batteries are balanced and have the same mah and "C" rating and made by the same manufacture.
Will
Will
#2354
actually i think i am just going to use my Watts Up meter that i have. that should tell me everything i need to know, plus its free since i already own it! i think i will remove the plastic casing tho. i just need to put it somewhere that i can read it without removing the body.
thanks
thanks
