HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 07-20-2010, 08:51 AM
  #2176
mebolson's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Kylesfv View Post
what hop ups would u recomend for teh vorza
If you are racing:
Better servo
Aluminum steering arm
M2C outside hinge pins
Otherwise the car is solid.
E
mebolson is offline
Old 07-20-2010, 09:38 PM
  #2177
Kylesfv's Avatar
Angry
i need helpppppp!!!!! i programed the esc and when i pull the trigger toward me it goes in reverse isnt it supposed to go foward
Kylesfv is offline
Old 07-20-2010, 10:05 PM
  #2178
Don't know about your HPI rig, but my Spektrum DX3.0 has a feature to invert the throttle/steering so try looking through your manual for such feature.
RepEvox is offline
Old 07-20-2010, 10:39 PM
  #2179
kman16jr's Avatar
Trader Rating: 56 (100%+)
Default settings
Which settings did you mess with?i need to know this first before i can give you accurate answer.You should be able to swap any of the 3 motor wires around to make it go forward.Still tell me the settings that you messed with to see if your not gonna mess any thing up.
kman16jr is offline
Old 07-21-2010, 07:03 AM
  #2180
Kylesfv's Avatar
i did what the manual said foward than re3verse then nutral .... the after it finshed the controls were messed up
Kylesfv is offline
Old 07-21-2010, 12:19 PM
  #2181
Vision's Avatar
Trader Rating: 41 (98%+)
Switch 2 of the wires going to the esc and re-program the esc to the radio. Should fix the issue
Vision is offline
  #2182
Vision's Avatar
Talking
Selling the wide conversion kit for the vorza, getting another r/c in the future. Check it out here -
http://www.rctech.net/forum/r-c-item...rsion-kit.html
Vision is offline
Old 07-21-2010, 12:51 PM
  #2183
Kylesfv's Avatar
i swithched the cable and re did then it went in the right direction but forward was slow and reverse was in sanely fast
Kylesfv is offline
Old 07-22-2010, 07:39 AM
  #2184
Vision's Avatar
I would check the esc settings also using the castle link on your computer to see if everything is ok there.
Vision is offline
Old 07-22-2010, 07:45 AM
  #2185
HYDE16's Avatar
Default ESC Firmware and Settings
So it's been a while since we've brought up the latest Castle Creations ESC firmware and our settings.
Last we spoke, Paulie (pgeldz) said he tried installing the V3.25 software.
Has anyone else tried this one or is there a newer version out there?
Also, we've spent some time with our cars on the track to get our setups right. Has anyone really refined the ESC programmable settings since their intial testing?
Where are you guys now and can you post your current settings?
I find that my car is overly powerful for the mid to small size track I run at.
I'm overshooting turns and loosing traction due to the amount of torque.
I'm wondering if I should scale back my car near training mode to keep it controlled.
HYDE16 is offline
Old 07-22-2010, 07:54 AM
  #2186
Trader Rating: 44 (100%+)
I stay current with the firmware and have yet to run into an issue. I even run the betas when they are available.
I've discovered through testing and asking a lot of questions that it is best to disable most of the programmable functions in the ESC and tune control through your radio. I'm talking about stuff like disabling punch control, only running 25% or less brakes, no drag brakes, no throttle or brake curves, etc. Run 0 timing and low initial start speed.
Tune with your radio. Start out at 25% throttle EXPO, turn up the EPA on your brakes until you find the sweet spot, etc. The result of all of this is less heat in the ESC and motor. You are also more in control of things with your throttle finger.
I ran like this at my last race and was much happier with my temps and the way my buggy ran.
I'm still working out suspension tuning. I'm going to try some 1.2 shock pistons in the rear and experiment with shock oils. This should give me more pack on high speed hits and help prevent bottoming as much while still allowing the suspension to move appropriately over the small stuff. We'll see.
ben
armourbl is offline
Old 07-22-2010, 08:35 AM
  #2187
Firesun's Avatar
Does your radio controller have a switch on the top that says "reverse".
If it does, click it to that.
See if that solves your problem.
Firesun is offline
Old 07-22-2010, 10:16 AM
  #2188
See the attached picture. I drew this up really quickly in MS Paint. This is how my motor is wired to the ESC. Set your's the same. Make sure in the ESC software that your motor direction is not reversed. Also make sure your radio throttle isn't reversed, should be a switch on the stock radio, one for throttle and one for steering.
Beyond that, you need to go to your local hobby shop with your buggy and radio, batteries, etc., and ask them to help you.
ben
armourbl is offline
Old 07-22-2010, 10:19 AM
  #2189
Forgot to attach the file. Here it is...
Attached Thumbnails HPI Vorza Flux 1/8 E-Buggy Thread-wiring.jpg
armourbl is offline
Old 07-22-2010, 12:15 PM
  #2190
Trader Rating: 47 (100%+)
ben
Ben,
Good advice with the remote vs ESC settings. Keep us posted on how the suspension tweaking goes, seems like most of us that race are still having issues getting things just right.
jcbudny is offline
