HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 07-06-2010, 09:05 AM
  #2071
Mr. Mya's Avatar
Originally Posted by armourbl View Post
Sorry, got distracted. I used Loctite on the diff carriers top and bottom, motor mount screws, but not the locking screw.
ben
Thanks!
Mr. Mya is offline
Old 07-06-2010, 09:26 AM
  #2072
HYDE16's Avatar
Droop can also be adjusted by twisting the ball ends at the end of the shock shaft. I didn't have screws either.
Originally Posted by Mr. Mya View Post
I've seen that video before, it helped me learn how to set up my ride hieght when I first started. Thats a almost perfect video, the only down side to it is, if you're new and don't know where to adjust the droop or how to make any adjustments you can kind of get lost because he doesn't actually make any adjustments. Now because the Vorza doesn't come with droop adjusting screws, I didn't understand how to adjust droop until I picked up a Losi 8ight-E 2.0 that has the droop screws installed. Yesterday I actually went ahead and order a set of Losi screws for my Vorza.
HYDE16 is offline
Old 07-06-2010, 10:09 AM
  #2073
Mr. Mya's Avatar
Interesting... I did not know that you could do that. Does that just limit and or extend the length of the shock to get the desired amount of droop? It seems that it might put a little unwant strain on the shock ball ends.
Mr. Mya is offline
Old 07-06-2010, 10:17 AM
  #2074
HYDE16's Avatar
To get to my droop settings I only extended them a tad.
There was plenty of thread still within the ball end. I only had to back them out slightly. Haven't broken one yet.
HYDE16 is offline
Old 07-06-2010, 10:22 AM
  #2075
Mr. Mya's Avatar
Cool... good to know!
Mr. Mya is offline
Old 07-06-2010, 10:35 AM
  #2076
HYDE16's Avatar
So here's a quick question,....how do I eliminate the squeaks?
Our track can be very dusty and at this point when I even touch the car it squeaks like my wife while watching a scary movie....
After the races I spray the a-arms and hubs down with the losi electronic cleaner. I also have 3-in-1 oil but I'm not sure where to apply.
Do I need to take the a-arms apart and clean them out too?
HYDE16 is offline
Old 07-06-2010, 12:54 PM
  #2077
Trader Rating: 44 (100%+)
I coat the moving parts with WD-40. Most of the squeaks come from the ball ends on the turn buckles and steering linkage. But I also get the hinge pins, shock ends, etc. Anything that moves when you flex the suspension. Squeaks go away and stay away until the lube dries out.
I'd be careful about allowing the shocks to be the downstops for your droop. As mentioned before, it would be better to use the stop screws to limit the doop. Only reason to extend the shocks by unthreading the bottom would be because you want to run more droop than the shock will allow.
ben
armourbl is offline
Old 07-06-2010, 01:05 PM
  #2078
HYDE16's Avatar
Thank you Ben.
I have installed the screws since then to match the droop I currently have.
Now the screws are limiting the amount of droop to take the stress off the ball ends.
HYDE16 is offline
Old 07-06-2010, 04:40 PM
  #2079
Trader Rating: 47 (100%+)
I'm new to all of this and trying to set up my Vorza for its first race this Thursday. Could you be so kind as to link the Losi screws you are referring to for droop, and would anyone be willing to post a picture of where the drop screws are inserted to adjust the droop? I have a general idea from looking at my arms but want to be sure.
Really appreciate the great info guys, please keep it up!
jcbudny is offline
Old 07-06-2010, 04:43 PM
  #2080
Save yourself some time and money. Go to your local Ace Hardware store and pick up some M4 x 10mm hex set screws.
As for the location, look on the bottom of your chassis where the bulkheads connect (4 screws). See the little wing that extends out, directly above that is the hole for the screws in your a-arms. The screws push on that little wing when you adjust them down.
The blow-up of the parts in your manual shows the screw location and part number. It starts with a Z if I remember right.
ben
armourbl is offline
Old 07-06-2010, 04:47 PM
  #2081
Here, this pic should help.
ben
Attached Thumbnails HPI Vorza Flux 1/8 E-Buggy Thread-picvorza.jpg
armourbl is offline
Old 07-06-2010, 05:05 PM
  #2082
ben
Ben,
Thanks for the help with this, that is the location I had assumed to be correct, but knowing for sure helps. Is this hole threaded then so that when the screw is inserted it pushes down on the aluminum wing from the chassis?
jcbudny is offline
Old 07-07-2010, 07:48 AM
  #2083
Ben,
Like most plastic, it isn't threaded, but the screws will cut threads the first time you install them.
ben
armourbl is offline
Old 07-07-2010, 10:00 AM
  #2084
Mr. Mya's Avatar
Bens way will work just as well, but to answer your question, I get all my Losi parts from www.losipartshouse.com part# LOSA6295
Mr. Mya is offline
Old 07-07-2010, 08:50 PM
  #2085
durgaman's Avatar
hey guys
what are your opinions about the vorza? is it, um a durable car to go on the bashing side of things since i dont race anymore? or would i be better off just getting a MT for $799 australian dollar
durgaman is offline
