HPI Vorza Flux 1/8 E-Buggy Thread
#1996
can someone tell me whether ve8 pinions will fit the vorza?
the vorza gears are mod 1 pitch with a 5mm bore....
#1997
#1999
Hello you'll,
I just installed 112mm on my Vorza and with stock white springs, I have settled on 37.5 wt losi oil. Manual that came with the shocks recommend using 35 wt while stock shokc had 45 wt.
Are the orange springs much better? I reckon spring rate is higher on those hence the 50wt oil.
Anyway, it'd be good to see what others are using so I can set mine up appropriately.
I like the orange way better, the white spring were just too soft, made the ride kind of sloppy.
#2000
I finally installed the Elite RC mount that I ordered a few weeks back, and I am extremely impressed by the craftmanship! This mount is seriously a work of art! I had to Dremel off most of the heatsink pins from the bottom of the motor, and cut the mounting screws a little, but it fits perfectly!
I brought the Vorza to the track last night for our Thursday racing, dominated the Xray 808s and Losi 8ight 2.0s, took TQ and the win. The most important thing I noticed about the mount is that it seemed to run so much smoother. Also, the loud crunching metal sound of the gears seemed to dissipate. And yes, I set the gear mesh the same as I did for the stock mount, so I'm convinced that the Elite RC mount is mostly responsible for the softer sound.
Anyway, thanks longbill! This mount is awesome!
#2001
pictures?
#2002
I posted pics of mine a while ago.
ben
#2003
Hey Ben, did you post pictures of the Flux motor mounted in your Vorza?
#2004
got a quick question here. the plastic tubes that hold the steering posts, are they supposed to be touching the chassis when they are installed properly? or there are supposed to be a little gaps in between?
please help!
please help!
#2005
I didn't get around to taking them last night, since I was racing, but I'll try to remember to snap a few before I head out of town this weekend.
@armourbl - I loctite'd the mount screws on the bottom of the chassis, the screws that hold the motor to the block, and the screw that sets the mesh. It all held up great through 3 7-minute heats and a 10-minute main
#2006
Here you go Hyde. Since I have everything loctited and I'm about to go out of town for the weekend, I didn't want to take off the motor to show all the heatsink pins I cut off, so I hope that's forgivable
The area inside the red box in the 3rd image are the rows of heatsink that i chopped and ground down a bit with my dremel. Honestly, it could use a little more grinding, but I didn't have the time, and it didn't seem bothered while running. Those heatsink pins are ground all the way around the bottom, to about the same spot on the other side.
I took about 3mm of length off the chassis mount screws because the hole in the mount is more shallow than the plastic diff mounts.
Hope this helps! It really is an awesome mount
#2007
#2008
ben
#2009
How do the driveshafts do with the center diff being taller, do they pop out at all?
