HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 04-14-2010, 05:10 AM
  #1636
HYDE16's Avatar
You could also get M2C Racing captured hinge pins, they work perfectly for me
HYDE16 is offline
Old 04-14-2010, 05:26 AM
  #1637
Originally Posted by bayvaleslash View Post
would this be a good race buggy for the track?
It could be but you would have to set it up right. i saw a Vorza smoke a 8ight e 2.0 in a race... you just have to get the right tires and shocks that fit u
T Train is offline
Old 04-14-2010, 07:20 AM
  #1638
Trader Rating: 44 (100%+)
Originally Posted by Silence View Post
Why add washers on the wheel nuts? I may not be understanding where you are suggesting putting them.
where can you get the skid plates I have looked all over!
The a-arms have two sets of hinge pins. The first are close the chassis and allow the arm to pivot for the suspension travel. The other is at the end, near the wheel, and allows the hub to pivot, this is referred to as the outer hinge pins. There is a tiny screw right next to it that is supposed to retain the pin and keep it from sliding out. But the washer doesn't cover the pin enough, so by adding a washer you make it working better and prevent the pin from coming out.
You can do that our replace them with capture style hinge pins, which have threaded ends and nuts to keep them in place.
ben
armourbl is offline
Old 04-14-2010, 12:16 PM
  #1639
Mr. Mya's Avatar
Originally Posted by VanillaTony View Post
video of friend and me at the track
Keep in mind this is our first time at a track ever. We have know idea what we are doing.
http://www.youtube.com/watch?v=adfyVK8Ndow
Hey... thats one of the tracks I go to also. I'm a newbie also to the track scene. We should meet up out there some time and practice.
Mr. Mya is offline
Old 04-14-2010, 01:19 PM
  #1640
Mr. Mya's Avatar
Originally Posted by mebolson View Post
Has anyone tried the field link for the ESC yet?
E
I do use one. The Field Link is nice for your basic settings, that way you don't have to drag around a laptop.
Mr. Mya is offline
Old 04-14-2010, 06:13 PM
  #1641
VanillaTony's Avatar
Cool man I'll message you next time I go.
VanillaTony is offline
Old 04-14-2010, 07:42 PM
  #1642
danulmer18's Avatar
Also could someone please tell me what springs would be stiffer than stock to put on?
on hpi's site it looks like all the springs are softer than stock but there are different lengths.
What has everyone been changing theirs too? why?
Thanks!
here are the springs, softest on top:
60MM`SPRINGS (USE WITH STOCK 97MM SHOCKS)
GREY
WHITE
BLUE
ORANGE
68MM SPRINGS (USE WITH STOCK 97MM SHOCKS)
GREEN
YELLOW
RED
76MM SPRINGS (USE WITH OPTION 112MM SHOCKS AND EXTENDED TOWER)
GREY
WHITE
BLUE
ORANGE
For the track you need some heavier rear ones for sure. I went to 68mm red.
Still wanting to know what other racers are using for springs and oils?????????
danulmer18 is offline
Old 04-14-2010, 08:34 PM
  #1643
outtafocus's Avatar
Finally received my Turnigy 5200 2s packs today.
I noticed that the wires come out in the center of the hard case. Has anyone running these type batteries had any fitment issues? Or even have these batteries at all?
I am still waiting on my order of Vorza bits to show up from Hpi so I am unable to do any test fitting yet.
Also with the Turnigy batteries, who is still running the stock 5.5mm bullet connectors? With one female and one male connector, I am a little nervous having the exposed male (always be nervous around exposed males)
connector just out there, I know it on the negative lead but makes me wonder.
Those still using these or even the C.C. bullets have any wiring tips to keep everything safe?
outtafocus is offline
Old 04-14-2010, 10:04 PM
  #1644
ben
Ok perfect I see now, Ill have to take a look at mine then.
Ne word on where or what part # from who I can get those front and rear skid plates?
Thanks!
Silence is offline
Old 04-14-2010, 10:09 PM
  #1645
GREY
WHITE
BLUE
ORANGE
GREEN
YELLOW
RED
GREY
WHITE
BLUE
ORANGE
Thanks! Great Ill have to order up some red springs for the rear. Did you change your fronts at all? Did you change your oil right away when changeing spings? if not will there be a noticable difference with springs alone?
I would still like to hear what others are using for springs and oil for sure!
Silence is offline
Old 04-15-2010, 12:42 AM
  #1646
I'm using bullet connector on my ESC, so I kept the bullets on my 6S. The male connector is a little bit exposed.. But I just put a bit of tape on it.
Limpan is offline
Old 04-15-2010, 01:46 AM
  #1647
wrexxy's Avatar
Default DE Racing skid plates
Does anybody know for sure whether or not these DE Racing skid plates will for the Vorza? They're meant for the D8.
http://www.deracing.net
wrexxy is offline
Old 04-15-2010, 05:21 AM
  #1648
skdd.morse's Avatar
Yes they work great....
skdd.morse is offline
Old 04-15-2010, 11:14 AM
  #1649
Mr. Mya's Avatar
I have the DE's on my Vorza and they fit perfect!
Mr. Mya is offline
Old 04-15-2010, 11:30 AM
  #1650
Mr. Mya's Avatar
Front - Gray/60mm 42.5wt Losi oil, Rear - 112mm Shocks - Orange/76mm 50wt Losi oil.
Mr. Mya is offline
