HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree16Likes
Old 04-02-2010, 10:02 AM
  #1561
Trader Rating: 44 (100%+)
Originally Posted by Mr. Mya
I have a new one on order with EDS, I should be getting it any day now, I'll let you know the depth when I get it.
Why not just pick up a thin walled deep socket from the hardware store?
ben
armourbl is offline
Old 04-02-2010, 10:08 AM
  #1562
Mr. Mya's Avatar
ben
Of course that would work just fine. I actually ordered a whole tool kit from EDS and the 17mm wrench is just one of the tools I have in the kit.
Mr. Mya is offline
Old 04-02-2010, 11:41 AM
  #1563
Mr. Mya's Avatar
Has anyone messed around with their throttle curve or brake curve yet? I really don't know exactly what this setting is for nor what to do to make better proformace adjustments with it. Anyone... everyone???
Mr. Mya is offline
Old 04-02-2010, 11:42 AM
  #1564
HYDE16's Avatar
Nope, I just program the percentages and let it automatically calculate the curves.
HYDE16 is offline
Old 04-02-2010, 03:26 PM
  #1565
I wish there were more info available on various curves as well. I don't have the patience to try stuff out, not even sure I'd notice the changes...
Question the diff fluids: I didn't read the manual well enough to notice the part about how much to fill the diff. Not knowing any better, I filled them to the top instead of just above the diff shafts. What affect will over filling have?
ben
armourbl is offline
Old 04-03-2010, 04:03 AM
  #1566
wrexxy's Avatar
Default BMX 5S
For those few who live in Australia and have visited Castle Hill BMX track in Sydney - The vorza was coming off the starting-grid downramp & clearing the first big triple on 5S. Judging by the scale on google maps, it's about 12-14 meters (40-45 feet).
Love it.
wrexxy is offline
Old 04-03-2010, 08:33 AM
  #1567
bmitchell373's Avatar
On the curves, alot of it is personal preference. I drive with an aggressive throttle profile. To where Im getting more throttle with less trigger pull. Its nice if you have a laptop, take it to the track and play. but if your bashing no need. But i will say on 4s with the timing turned all the way up, it screams over stock timing.
bmitchell373 is offline
Old 04-04-2010, 03:32 PM
  #1568
VanillaTony's Avatar
video of friend and me at the track
Keep in mind this is our first time at a track ever. We have know idea what we are doing.
http://www.youtube.com/watch?v=adfyVK8Ndow
VanillaTony is offline
Old 04-04-2010, 05:11 PM
  #1569
That was a great video. Loved it.
ben
armourbl is offline
Old 04-04-2010, 10:14 PM
  #1570
mebolson's Avatar
Trader Rating: 41 (100%+)
Has anyone tried the field link for the ESC yet?
E
mebolson is offline
Old 04-05-2010, 07:25 AM
  #1571
HYDE16's Avatar
So here’s a bonehead move for you all……
I decide to go out and get an 18T pinion gear so I can swap out the stock 15T.
I take the 15T off, put the 18T on and strap the motor back into the motor mount.
I look down and the motor shaft is cocked on an angle. I freaked out and removed the motor right away.
I put the 15T back on because I was in a panic, ended up stripping the 16T allen screw when tightening it back in and had to play with the gear mesh for 30 minutes to get it right again.
Every time I screwed the motor mount in to set the gear mesh correctly I could feel the screws tightening in and pushing the motor mount towards the spur gear.
Meaning, they didn’t just screw in straight and lock in the position I had, as I tightened them down it would shift the motor mount slightly making it nearly impossible to get the mesh set right.
Every time I thought I had it set it would either not roll forward freely due to binding or would make a grinding sound because it was too loose.
I finally got it right and it rolled freely and drove just fine. There is no damage to the motor or motor shaft that I can tell.
I feel like I may have stripped some of the motor mount threads where it mounts to the chassis and also where the straps come over the motor.
Think I should get another motor mount to be safe since the gear mesh needs to be so precise?
Turns out the 18T pinion diameter is larger than the 15T and I never adjusted the motor mount location by loosening the screws under the chassis to give it room.
Such a bonehead move, luckily this buggy is super tough with all of the mistakes I have been making. I’m rusty after getting back into this after 10 years.
HYDE16 is offline
Old 04-05-2010, 09:18 AM
  #1572
So how did it run with the 18. Could you tell any change?
Old 04-05-2010, 09:35 AM
  #1573
I've got an 18T, but haven't tried it. I can't imagine this buggy with more top end. It is already a handful. On 6S it is insane. 4S really gets the job done without pushing the bounderies. Any faster and it would be time warping back to 1985....
"If calculations are correct, when this baby hits 88 mile per hour, you're gonna see some serious shit!"
http://www.moviewavs.com/php/sounds/...riousBLEEP.wav
armourbl is offline
Old 04-05-2010, 09:43 AM
  #1574
Lgbzone's Avatar
The NEO2010 A main is about to start
http://www.livestream.com/newchannel...nnel=bbkrclive
Lgbzone is offline
Old 04-05-2010, 09:49 AM
  #1575
Awesome, so much for getting work done. LOL
Did you see the dude dressed like a Ninja swinging the sword to let the cars on the track. LOL.
ben
armourbl is offline
