HPI Vorza Flux 1/8 E-Buggy Thread >
Like Tree7Likes
Old 03-25-2010, 08:25 PM
  #1516
Originally Posted by VanillaTony View Post
Quick battery question
I have a 3 cell 4200 mah 11.1 25c battery. The guy at the store said to charge it at 2.5 (as from the 25c) but my charge times are really long and I was thinking something is wrong.
So I googled it and it says to go by the mah rating. So I have a 4200 mah so I can go has high as 4.2 amps right?
You will be good with 4.2 amps = 1C charge on a 4200mah lipo.
At 1C charge it will take 1 hour (in a perfect world) to charge a Lipo from 3.2 volts (empty) to 4.2 volts (full). Battery temp and balance will play in to your charge times. Some manufactures advertise 2C+ charge and will give you a faster charge time. 2C (8.4 amps on a 4200mah bat) would give you a 30 min charge time from empty to full. Stick to 1C and your batteries will last along time (a-lot of charge cycles). You should refer to the battery manufacturer web page for specifics on charging your battery.
Kodiak ak is offline
Old 03-25-2010, 08:45 PM
  #1517
VanillaTony's Avatar
thanks man
VanillaTony is offline
Old 03-26-2010, 05:43 AM
  #1518
wrexxy's Avatar
Originally Posted by KeithM View Post
Its no slouch
Im still impressed with its offroad performance on 6S
6S for regular driving offroad 'eh? Vision & KeithM... you are both certifiable nutbars. I'll need to get used to 5S before I even think about 6S on a track!
wrexxy is offline
Old 03-26-2010, 10:20 AM
  #1519
Trader Rating: 44 (100%+)
Finally got some proper tires for the Vorza. Picked up some nip Proline Crimefighter M2's premounted from a guy in the for sale forum.
There are slightly taller and wider than the stock rims and tires, and have much more dense foam. These are going to make a huge improvement in the handling.
Sorry for the blurry photo...
And here is a photo of my mud guards that were made out of a MX goggle lens. They are holding up perfectly, although dirty in this photo.
armourbl is offline
Old 03-26-2010, 11:05 PM
  #1520
wrexxy's Avatar
Default Proline INSIDE JOB
Bought some Proline Inside Job tires, not too bad but I wouldn't say they last too long on the Vorza.
2 Lipos worth of laps on my local clay circuit (One 4S and one 5S) and they are now essentially slicks.
wrexxy is offline
Old 03-27-2010, 07:32 AM
  #1521
Why is this battery so cheap? What am I missing. Need a new set and looking for a good deal. Will this battery explode on impact or something?
http://www.hobbypartz.com/83p-5000mah-6s1p-222-30c.html
Old 03-27-2010, 08:34 AM
  #1522
Lol, no
I bought my 6S from Hobbyking for 69$, and it's great. That one you linked is probably good too.
Limpan is offline
Old 03-28-2010, 03:58 AM
  #1523
HYDE16's Avatar
Has anyone tried plugging their battery it into one of the ESC connections without a jumper harness (plugs into both ESC connections)?
HYDE16 is offline
Old 03-28-2010, 05:24 AM
  #1524
You have to close the circuit.You cant leave one connection open.You need a jumper if no harness at least.
bnangle is offline
Old 03-28-2010, 07:53 AM
  #1525
I just got done changing out my rear dogbones for vorza front cva's I won off ebay.So far no difference I can see.Maybe a little quieter because less play than dogbones.Also I bought badland xtr wheels and they are so much better than stock.
bnangle is offline
Old 03-28-2010, 12:42 PM
  #1526
Just a work of advice. Don't run those Dynamite road tires with 6S. LOL The rubber won't stay connected to the wheels. Should have known better when I saw the fronts ballooning.
Caught it in time that I could re-glue them, but don't know if the repair job will hold.
Also, check the front CVD's. Had a pin start to back out. Also caught that in time thankfully.
ben
armourbl is offline
Old 03-29-2010, 09:01 AM
  #1527
Forgot to mention that the fan in my ESC stopped working. It no longer spins up during the power-on cycle, and it was reading 160-170 degrees with my temp gun and no fan turning.
I emailed HPI and they are sending me an RMA to send it in for inspection/repair/replacement.
Luckily, I have another CC system that I can run while the stock unit is at HPI.
ben
armourbl is offline
Old 03-29-2010, 04:42 PM
  #1528
Woa, this thread sure did slow down all of a sudden.
I wanna ask about diff fluid if any of you are still looking...
I changed mine this weekend. When 5 front, 7 middle, 3 rear. I noticed that my on power steering was reduced quite a bit and my front tires were unloading and ballooning. This was especially noticable on the street.
I read that thicker fluid in the middle will give a more all-wheel drive feel, increase on power steering, and help prevent the tires from ballooning. The fluild that was in the middle stock was definately thicker than 7,000.
Would you guys recommend increasing the middle to 10,000 weight? What about the front, leave it alone or go up to 7,000 as well.
ben
armourbl is offline
Old 03-29-2010, 06:49 PM
  #1529
danulmer18's Avatar
ben
That is the only crap thing about this speedy. My fan lasted about 20 minutes till a little rock blocked it and burnt it out. I cut the case open so it could breathe as well as sealing it. I left the fan wires exposed in case I want to put one on but the heat sink hasn't gone above 70 degrees even in summertime australia so I don't think a fan is needed.
danulmer18 is offline
Old 03-29-2010, 08:03 PM
  #1530
mebolson's Avatar
Trader Rating: 41 (100%+)
The twins:
Almost ready for the season!!!
E
mebolson is offline
