Hyperion Power sources
I have a bantam bc-6 charger and plan to upgrade to a hyperion. Either the duo3 or 7s charger. My bantam takes way to long to charge everything from my 2s to 6s. I need something faster.
What are you guys using for a power source for the hyperion's? Can you provide links?
I use a Power Force 30 amp model.
The Hyperion Duo 3 will be the last charger you buy ever.....
It will charge anything and do two batteries WITH balancing at a time up to 6S.
Buy it at www.teamhelotes.com
The best price anywhere for Hyperion chargers and batteries.
I run my Hyp 0610iNet charger with a Radio Chack 25a supply or a ProPeak 20a PS, either one works well.
If you have to get a supply from Tower, the Team Checkpoint 25a supply is prob the best value for the money. There are others (Integy, Team MuchMore) but they are more expensive.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWGU8&P=7
Super Moderator
Trader Rating: 31 (100%+)
I have the Team Checkpoint that Duster listed. I like it, I mean how much hype can there be over a PS. They either work or they don't and this one does.
Ditto on the Team Checkpoint PS...
I run two Hyperion 720i's off it at 10 amps a piece for my bigger batteries and all performs great!
