17.5 brushless and 27 turn brushed
Is a 17.5 brushless and 27 turn brushed motors the same ???? im looking for 17.5 brushless sensorless but having problems getting one. if someone could point me in right direction . i have a sidewinder with 4600 kv motor and i want a 17.5 to race the reedy trk champs at the end of the month. if cant get one i may just 27turn brushed motor for that race thnx in advance
Super Moderator
Trader Rating: 31 (100%+)
The ONLY sensorless 17.5 i've seen...
http://www.nitrorcx.com/brushless-mo...ze--3650-.html
I picked up a combo with 60A ESC 5.5 motor and ordered one of the 13.5's to go with it... not a bad basher set up BUT I will say my Novak 13.5's are not only better quality they pull harder and are a touch faster... all though I have not run the 17.5 i would say you'd be at a disadvantage running it against Novak, tekin, speedpassion and so on motors in a race.
BTW the Ezrun .5 motors are TRUE 540 size motors and not 380's stuffed in a 540 size can... the two Ezruns i have run cool and strong and for the money are hard to beat for a basher... I'd be looking to buy something better if i wanted to WIN races
are those roar approved motors thnx for the info
http://www.roarracing.com/approvals/brushlessmotors.php
Pretty sure they aren't roar approved. I run a 13t ez run motor(blue finned can). It does run hot but its a great motor. I get about 130 degrees F after a race(not going easy on it). It does lose power as it get hot during the race but only in the bottom end. I'm planning on getting the 13.5 sensor less ones once they come in stock again.
fyi...it is known that sensor less is more powerful than sensored though it doesn't have the silky smoothyness to it.
Go to the Express Motorsports website and order a 17.5. It will run great with sensorless and sensored speed controls. Worst case, the Trinity Duo motors are the way to go and will work with sensored and sensorless speed controls.
Not so true.. some of the fastest guys in our area run brushed still... But you need to know how to tune and maintain them if you want to stay fast...
Combine new LiPos with brushed motors and you get some ponies!
On the other hand, brushless is consistently fast once you get the gearing right!
Jerome
Jerome
