Slash questions
Old 08-20-2009, 06:08 PM
Default Slash questions
Hello all. A few days ago I picked up a Slash. I'm looking for new wheel/tire options as a first simple little change. I run mostly on fine gravel and pavement at the moment. There isnt much of a selection of slash tires and wheels so I was curious about the RPM revolver wheels. They are 2.2" but I don't know if they would work and if I should get all rears or fronts. Also would the Pro Line Switch m2 tires be acceptible for the surfaces I'm running on?
E1T1 is offline
Old 08-20-2009, 06:30 PM
maxair45's Avatar
Trader Rating: 18 (95%+)
I do believe the hex's are the same sizes on the front AND rear. For bashing i'd say the stock wheels and tires are good. If your racing then thats a differant story(unless stock spec if not as the local fast guys what they reccomend). The RPM rims like to break and chip away I suggest staying with the stock rims, they are the best performer i've used.
Hope this helps
maxair45 is offline
Old 08-20-2009, 06:37 PM
Trader Rating: 21 (100%+)
They work, but there is an offset diff. I run them on my Slash.
If you're trying to maintain something close to stock offset, run the fronts, the fronts keep the wheels pretty much under the fenders. The rears stick out a out farther (increase offset).
Duster_360 is offline
Old 08-20-2009, 06:54 PM
sLaSh It UPP's Avatar
i love my switch tires on my slash they handle perfectly
sLaSh It UPP is offline
Old 08-20-2009, 07:19 PM
Thanks for the replies. Now I'm off to read up on painting lol.
E1T1 is offline
Old 08-20-2009, 07:33 PM
have fun
