Reciever antenna...
Old 08-20-2009, 03:14 PM
maxair45's Avatar
Trader Rating: 18 (95%+)
Default Reciever antenna...
I tried taking my JR sr300 rx out of my xxxt and into my sc10(go it today) and I broke the wire. I know I can open up the rx, unsolder the broken antenna, and solder on a new one but will this work?
maxair45 is offline
Old 08-20-2009, 03:23 PM
CClay1282's Avatar
If its a spektrum rx, i dont know.
If its a regular crystal or synth rx then yes it will but you must find out the correct guage and the correct length. Those are important.
CClay1282 is offline
Old 08-20-2009, 04:32 PM
sLaSh It UPP's Avatar
yeah that is weird but i am not totally sure because it is specktrum
sLaSh It UPP is offline
Old 08-20-2009, 07:24 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
huh???.......the only issue would be if it's a coaxial antenna like the DX3R receivers, other than that as long as you use the same gauge and length wire you'll be fine.
racer1812 is offline
Old 08-20-2009, 07:58 PM
resolder it it will be ok. Dont over heat the reciever. Antenna needs to be same length.
bigde2001 is offline
