Gearing help????
Old 08-19-2009, 09:23 AM
cbringet4's Avatar
Default Gearing help????
i have slash with the novak havoc 13.5 system in it i am runing a 86 spur and a 18 pinion it dosent seem much faster then stock any info how to make it faster with out smoking the motor ? and what shock oil should i use for racing on a clay track with some decent size jumps i have the integry piggyback shocks for front and rear. they came with 2 springs red and blue no instructions or info so have no clue what to use . thanks guys !
cbringet4 is offline
Old 08-19-2009, 06:40 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I ran about a 22 or 23 tooth with my 13.5, you really should use a temp gauge to set up your gearing. It's really the only way to tell if your running it too hot or not. You can run at 150-160deg. all day long.
racer1812 is offline
Old 08-19-2009, 09:17 PM
cbringet4's Avatar
i was out tonight and i have a 20 tooth pinion and 86 spur i couldnt get any hotter then 112 should i gear up more ? i want to to be faster then what it is
Old 08-19-2009, 10:46 PM
If you still want more speed, just gear it taller a little bit at a time (larger pinion or smaller spur accomplish the same thing). Keep checking temp several times throughout a run. You don't have to gear until the motor is always at 160, gearing lower than this lets you keep cooler temps, longer run times, and more control.
wheelhaus is offline
Old 08-19-2009, 11:56 PM
Matt Sunderlage's Avatar
I've always used a 10.5 Novak motor in my SLASH and have geared it 22or23/86. This is with an LRP TC Spec speedo with throttle map on 2 for outsde 4 for inside. Don't notice much difference in motor temp between the 2. I always go by the 4 sec rule, if you can hold your finger on the motor for 4 sec after your race your probably ok.
I've noticed brushless motors just like to run warmer than you think it should. I still use my first 10.5 which is 2 years old and has benn "warm' thousands of times!!
cbrignet4- I'd just use the stock SLASH springs , they seem to work the best.
Matt Sunderlage is offline
Old 08-20-2009, 12:46 AM
LunchboX3904's Avatar
I've been working on my xxx-t's gearing with a 13.5 novak ss pro motor. when i first ran it, the gearing was set at 23/86 and the temps were about 100-110F max. Just today I went to 23/78 and the temps only went up about 10 degrees even in fairly deep, loose sand-like dirt with the paddles on After I test it out on my local track I'll probably be getting a bigger pinion.....maybe 25-28 tooth. I'm running nimh packs right now tho so the motor is probably a bit choked of power. Not sure how much would temps increase going to 2s lipos tho.
OP, keepin mind that our transmissions are different so final ratios will be different with the same pinion and spur.
LunchboX3904 is offline
Old 08-20-2009, 05:12 AM
Depending on where you run but locally I've seen a lot of 19/83 doing very well for gearing. I just switched over to Jato gears in my slash and know of people running that combo with Mamba's to great satisfaction. 9/58
Gearing is cheap and fast - take a day and experiment.
Human is offline
Old 08-20-2009, 08:47 AM
cbringet4's Avatar
thanks guys i will take a day and go test and fill you in later with any other ? i have
Old 08-20-2009, 01:57 PM
Super Moderator
racer1812's Avatar
Oh, and you said your "13.5 isn't much faster than stock" even geared proberly
(160 deg. after a 5 min race) my 13.5 isn't a whole lot faster than the stock motor, it has more bottom end power but top speed is pretty close. Your not going to see an earth shattering difference.
Old 08-20-2009, 06:44 PM
jato gearing what exactly are you talking about , would it help reduce temps in my mod slash
Darrel Smeltzer is offline
Old 08-20-2009, 07:20 PM
Super Moderator
racer1812's Avatar
Jato gears are 32p not 48p like the Slash, more durability, you can get more tooth contact with the "high quality" Slash top shaft/ slipper plates. It has nothing to do with motor temp. Motor temp has nothing to do with what pitch gears you use.
Old 08-20-2009, 07:55 PM
Default 13.5
can you pull the front tires of the ground with the 13.5??
J Blaze is offline
Old 08-20-2009, 08:33 PM
Super Moderator
racer1812's Avatar
No..and with stock tires you never will, they'll spin first even on carpet...why would you want too? Wheelies are cool but if that's what you want to do then buy a Stampede.
Old 08-20-2009, 08:42 PM
oops, I guess I should let you talk to my vxl slash, he's always pulling wheelies when I don't want him too (on clay)
bennybtl is offline
Old 08-20-2009, 09:04 PM
Super Moderator
racer1812's Avatar
with stock tires?? ohh and a VXL isn't close to a 13.5 which doesn't have the power to pull the front end up anyway.
