Mamba Max esc motor combo ? >
Old 08-19-2009, 09:03 PM
  #16
Originally Posted by ae rat View Post
running a truck through the grass really heats it up id stay off the grass.
very true.
You should use the lowest KV possible and very conservative gearing if you plan to run on grass.
Confirmed: ran my VXL + mamba max combo on 4S (with BEC disabled) on grass, temps were 180F after a 5 min run with my XXXT truck
outside temps were 90F.
The Slash is a bit heavier so I would not do that on 4S.
With that in mind i'd say it is safe to run on 3S with that combo as long as you keep the gearing conservative. (but do try to get a temp gun, it will help protect your investment)
by the way... I also smoked my 4600
Rufus2000 is offline
