Anybody ever thought of this?
I was just sitting here and i thought on a nitro engine couldnt you file a flat spot on the shaft of the engine and put a pinion gear on it just as you would do with a electric rc, also you wouldnt have to worry about clutches either.
has this ever been done?
I've had the clutch lock up on my 1/8th buggy before, it's very hard to drive. You can't stop or even go very slow as the engine will quit and braking is very touchy. I was able to finish the main but fell way back. You need a clutch so the engine can idle and can spool up under acceleration, way to think outside the box the clutch is as important as fuel or tires..........BB
Yes i realize that now, i wasnt thinking clearly
I have thought of one thing, a tri tip instead of a hex tip. No more stripped screws! So the hex will be like a triangle. But, knowing how I think the next big thing will be an octo-tip.
Hey have any off yall used this esc in a 8 scale, is it even for a 8 scale, is it any good,i cant seem to find a website that shows much specs about it.
http://cgi.ebay.com/Team-Associated-...#ht_2642wt_724
its for 10th scale brushless or brushed 6-8 cell nimh i think.
Oh ok, have you tried it yourself?
screws strip based on the materials used to make them...Hexs are way better than phillips and thats where it started
I agree, i hated it when my tamiya was all phillips. then rc screws came out with a full hex conversion.
