Regulator or not? >
Regulator or not?
Regulator or not?
Old 08-13-2009, 08:03 AM
chad24's Avatar
Default Regulator or not?
Hey guys i just got a d8 and converted it to brushless and running 4s 5500 lipo, and a mmm v3 esc, i was wounderin if i have to run a regulator to my reciver (nomadio React) or if i can just run it without a regulator? Thanks
chad24 is offline
Old 08-13-2009, 09:19 AM
jmcvicker's Avatar
MMM V3 has a BEC built in. Should power your servo/receiver just fine. Mine does :-)
Good ESC - did you hook it up to your computer yet to poke around with the LiPO cutoff and other stuff?
jmcvicker is offline
Old 08-13-2009, 09:21 AM
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
You shouldn't require a separate regulator for you system to run. I would however use some of those nice features that the Nomadio system has for Telemetry, including the voltage monitor and temp sensor.
what 4S 5500 battery pack are you using?
Cain is offline
Old 08-13-2009, 09:51 AM
chad24's Avatar
http://www.amainhobbies.com/product_...or-74V-5000mAh
nvm its a 5000mah not a 5500
chad24 is offline
Old 08-15-2009, 10:24 AM
No regulator needed
bigde2001 is offline
