Lipo Heat during a race
#16
I'm running 18/84 with a Tekin Redline 5.5 motor. My motor temps are about 145* after 6 mins racing. Here's something I thought of, do you have the body properly ventilated? Check this out.
http://www.rctech.net/forum/5930541-post3239.html
There's some pics of the vents in the body and the electronics layout. Hope this helps.
Hey JAM MaxAmps,
Don't take this personally, but this could have been an opportunity to extend a little customer service in some form. Instead you are showing a case of sour grapes. I'm not saying you do not have the right to be upset about ppl trashing your product, but ya could kill the nay sayers with kindness. Possibly offer the thread starter a little help in his quest for a replacement LiPo pack. Your call.
Hey JAM MaxAmps,
#18
Hey no problem here but it's tough at times to kill em' with kindness when it's the same guys over and over again saying the same old stuff. They just just don't get that we are here to stay no matter what they do or say as you can see from their very quick and sharp posts below. I don't really care what they say I just don't like to see a customer write us off like that and blame our product when it's clear that there are other issues that were more than likely the cause of the failure. Some people are just to quick to judge and then others with out looking at the whole picture try to take advantage of it and turn the whole thing into something it isn't. This thread could have been a good learning tool if people would have just tried to look at what was going on and tried to find a solution rather than to jump in and only use it as a chance to slam on us.
you want to know why people are out to get you?? its because you don't stand behind your product, castle,tekin,AE, etc have all had problems when they release somthing, did they blame it on user error?? no, the stood behind there products and got the bugs worked out. Not just tell them to go buy a new one.
#19
Check your gearing. If you came off the track with a pack at 122 degrees (And yes air temp adds to the pack temp) chances are it was a lot hotter than that before you got to it. That tells me your over amping the pack. That's what causes the heat and if they get to hot they do swell and will puff. I find it funny how everyone is so quick to blame the pack and not look at anything else they have done. But it appears you have made up your mind based on the ramblings of some that clearly just have it in for us. Go ahead and try another brand and keep running the same set-up I bet you get the same results. But hey then you can go around and call them all poor quality packs as well. One other quick note stressing an older pack like that is also going to cause problems.
Best regards,
Jason
Best regards,
Jason
#20
Best regards,
Jason
