Killer Deal for People Running 27mhz M8's
Hi guys.I have been running these reciever's for a while now and love them.
I know they work with the following radio's. Ko Mars(Not the mars R),EX-1,anything KO FM. But they also work with Airtronics while using airtronics crystals. I like them with my M8 and 3ps due to being SOOO small in size. These things are TINY.If your running a 3PS or a M8 and want some tiny reciever's check this out. Quality Reciever-$39.99NEW.Thats a SMOKING deal. I have been in this hobby a LONG time and when deals like this come up I try to pass them on. http://www.shopatron.com/product/pro...0.1922.0.0.0.0 If running a personal transponder just plug it into the battery slot or pigtail it off a reciever pack in nitro. Hope this helps some people. Les |
It's the same receiver that comes with the Presto. I used one this evening with my Helios, no problems. It just won't do the HRS, but for $40 it's a great receiver
Yea gary is correct.WONT work with the Mars R but will work with the helios just no HRS features when using it.
wow... i have an m8 (27mhz) and i still have a couple of these 27mhz receivers from KO... it'll be great to have extra receivers...
does any one have a clue why they'd work? is it because 27mhz is the most common band or that it has a lower frequency than 75? |
Highway I have seen guys do the same thing with 75mhz KO reciever's and Airtronics radio's.
The Ko's work if you use the airtronics crystal in both.Just make sure they are both 27. Les |
Thanks Les... will try it out. - jason
