Resetting ESC
I need to reset the Esc for my Bandit Vxl. The Esc is a Velineon Vxl 3s. I checked the manual and it didnt show how to reset the esc
. If any one knows I'd appreciate it.
you only have 3 things you can do. There is not Reset.
1. LVC - on/off
2. Calibrate ESC/TX
3. Profiles - 1,2 or 3.
What exactly is the problem??
1. LVC - on/off
2. Calibrate ESC/TX
I would guess his LVC is false tripping with the use of 3S packs. It's a common VXL esc issue. Go through the normal set-up steps for using a 3S pack if this is the case. Sometimes it works other times no go. If the esc is still under warranty you can try sending it back for a replacement. Other have opted to replace with an esc like the Mamba Max from Castle Creations.
Jason
Jason
Or just turn it off and be disciplined to stop when you notice power loss.
I know it sounds crazy
Jason
Jason
