Jammin SCRT10 Thread
#871
I believe the ProLine SC tires fit these wheels.
Check it out.... http://www.prolineracing.com/catalog/Wheels-33-1.html
#872
What have you guys been breaking? I am undecided between the scrt or the hyper. They both seem to handle amazing with the proper setup (watched 2 vids of Bradley and Kortz battling). Any issues with shock towers? I like how the Hypers is alum., but is it needed? Please give honest answers as I would with you. I understand that they break, so I just want to know what spares should be in my box.
Thanks,
Porty
Thanks,
Porty
#873
i bought enough spare parts to almost build another car. nowhere local has parts for these so i wanted to be ready. to date ive broke the front bumper. that happened on the first pack. thats it. we are running indoor in n.e. ohio but the one indoor track is pretty good size, and im no pro driver. i have crashed it pretty good, lawn darted it from a good height, this is one tough little truck! its not 1/8 tough but none the less i havent broke it. in the same time on the same tracks ive broke a couple a-arms on my b44 from simular crashes that my jammin has held up to. now that ive spent the money on parts i doubt ill ever break anything, thats the way it works i guess. hopefully something will wear out so i can put some of them to good use.
#874
I heard about boiling the front bumper...
#875
Thanks for the info Jimmy. The 3700kv 5.5 is probably the highest kv I'd want to run on 3S, but if it can still hang on 2S it sounds like the right choice seeing as some tracks are 2S and some allow 3S.
#876
Thanks,
Porty
Thanks,
Porty
Front bumper upper support (It takes a major beating I was surprised that it lasted that long)
and a right rear hub carrier. I landed completely wrong and it snapped.
#879
Thanks,
Porty
Thanks,
Porty
#880
Thanks,
Porty
Thanks,
Porty
I actually think the aluminum shock towers are a negative. Lots of guys have been bending them on the hyper. The aluminum they use is pretty thin. Seems like the jammin plastic ones would take a serious hit to break. Jammin also sells aluminum towers if you really wanted a set. I believe someone even makes carbon fiber ones.
#881
I talked to Proline today to find out when they are coming out with the offset rims for the scrt and the tech guy (who is sponsored by Jammin) said that they are running slash front rims all the way around. Are any of you running these and if so how do you like them. Thanks.
#882
I just got the scrt 10 and it seems to be very nose heavy...Have any others had this issue and what are you doing about it.....Thanks Doug
#884
If you look back at the last couple of pages there are a few posts regarding people running slash front wheels. So yeah some guys are running them. Personally I have slash rears all around.
