Jammin SCRT10 Thread
#8297
I wonder the same.... When I fly my large electric planes, ones that pull around 100A, it makes a difference what C rating the batt's are. I'm not certain how many amps these trucks pull, but if your running a 20c 5000 mah lipo it will discharge up to 100A w/o hurting it.
I'm guessing lipo's w/ a higher C rating are more efficient?
#8298
http://hobbycity.com/hobbyking/store...idProduct=9967
And a set of the thunder Power 50c saddle packs in my scrt with the hv4.5 motor and can't tell a difference really. Both batteries make more power than the tires can put to the ground. This is racing on a very high traction indoor clay track. In my opinion once you get to a certain point it doesn't matter any more. Especially with the powerful mod class motors. In "stock" classes where all of the motors are equal and every little bit of power matters,
it seems that the battery being able to hold just a little more voltage under load to make just a little bit more speed on the straight does become a factor.
#8299
It also depends upon gearing. I run 30C HK packs and when I'm geared for outdoor large tracks it sometimes hiccups a little in the corners. When geared for smaller indoor tracks, it runs like butter with the same packs.
I've added a glitch buster cap and it's better outdoors, but I'd probably benefit from a higher C pack. It'll also cog more when it's cold (and the packs are cold) while geared for the larger tracks because the voltage just can't keep up then.
#8301
I have some 5000 30c's and they like to cog/ cut out on larger track. I am going to look into another brand in the same size and see if its the pack or just the size. I am using a HV 4.5 motor.
#8303
SMC C-Max 5400mah - 4.5HV
Ditto on the SMC's: Been running SMC 5400mah C-Max Packs for over a year and with 4.5HV/Havoc Pro in weekly races. Many with double or triple 10 minute A-Mains. They get rotated and reused/bumped up during a tight schedule of heats and rotating 10 minute mains. It's crazy fun and the SMC's recover quickly.
But also started bust'n/beat'n on some H.King 5k's for $19.98 in practice.
#8304
I've run the SMC 5400 / 50C packs for quite awhile but needed a larger "gas tank" to make our 12 minute mains. I bought a Thunderpower 8000 / 22C and was pleasantly surprised there was no noticeable difference in burst or high speed power. I was a little worried that halving the C rating would make me have to alter my driving style....nope!!
#8305
Hey guys,
Has anyone tried running sc8 body mounts? They look as they could bolt right into the stock holes and they are more adjustable.
http://www.teamassociated.com/parts/details/89426/
#8306
Hey guys,
#8309
has anybody tried laying the battery down and put the esc and receiver down the chassis just to get more lower cg?
