Jammin SCRT10 Thread
#8161
Tim
#8162
Yeah I just got my T-Bone installed yesterday and it looks awesome, I don't think it will be breaking anytime soon. I ordered it from their website, got it to the house in a week. Looks like I got an updated model, had couple mounting holes to adjust the height of it, fits just in front of the headlights now. Will be running it this weekend to test it out.
Tim
Tim
#8165
I just installed a Traxxas Slash upper camber link through the stock bushing without a bar connection to the rear upper pin holder. I don't have a photo and can try to post one later.
Everyone should check out Lazer Guys front Bumper. That is what I was talking about up thread. It looks like a great way to keep the stock bumper and eliminate the connection from the bumper to the skid plate that rips the bottom out.
#8166
I also emailed RCM about the area under the spur not being milled deep enough and haven't heard back. Its not a huge deal to rectify but having to alter a brand new chassis to make it work properly kinda rubs me the wrong way. Especially something as apparent as that....
#8168
hey lazerguy can I get pic of the bumper mod.
I did the rear long shock conversion for the front end.
does that make a problem with trying to modify the SC10 front
bumper mod. I have the metal STRC front shock tower now.
warm weather seems to make the car invincible but now I have been
racing indoors and its cold here in NY I cannot get through one race night with out breaking. steering turnbuckles, chubs, and steering knuckles and front bumpers.
Is the PBS suspension more durable thinking about making the jump or
slowing the car down 5.5 with a 15tooth pinion just way too much even turned down on the radio endpoint.
any help will be appreciated...
#8169
Sorry to interrupt this thread, but does anyone know if this CRT.5 comes w/ the long chassis?
I can't get an answer on the crt.5 thread and need to order the servo's asap...
https://www.rcdeal.com/modules/store...m=1007&store=4
Thanks in advance,
Jordan
Thanks in advance,
Jordan
#8171
Tim
Tim
#8172
Ok folks. Need some advice.
I ran my SCRT-10 yesterday and she drove pretty nice. I'm a road driver/basher too. I noticed the center diff was leaking like mad. So I figure I'll gather the fluids and redo all 3. Can anyone recommend the fluid weights for asphalty power slide straights and figure 8 type of driving? Also what you recoomend I do to seal that center diff?
Moon
Moon
#8173
MoonDeville - There are a few things you can do for a leaky diff. First, make sure the diff case is flat. The part that the cover screws to. Sometimes, Ill take a piece of 120 or so grit piece of sandpaper and lay it on a very flat surface. i.e. glass, metal plate, etc and sand the diff case a bit. I then take the out drives out, clean them up and use mobile on grease to lube the out drives before I put them back into the case. I also put grease on the o ring. I then fill up the diff and make sure to clean the diff gasket really well so there is no diff oil on it. Then I take the mobile one and lightly coat each side. Screw the cover on and let her eat!
#8174
#8175
I just modded my T-Bone today so it slips under the front diff like the stock bumper mount does. I didn't like the the front skid plates' effect on ground clearance. If I start ripping up diff cases I guess I'll have to go buy a new one.
Darn tough bumpers....you won't break one no matter what you hit.
