Jammin SCRT10 Thread >
Old 01-09-2010, 04:02 PM
  #631
Originally Posted by GravityJunkie View Post
I've run plastic spur gears in my brushless CRT X2 and had no problems. I ran one gear most of the summer and it still looks new.
I grabbed a plastic gear for my CRT .5, but I haven't had a chance to put it in yet.
Thanks for the replies. I've never used a plastic spur off road so its good to hear they're holding up.
Cheers
enlighten is offline
Old 01-09-2010, 05:57 PM
  #632
Trader Rating: 83 (100%+)
Originally Posted by bigbeej View Post
Now that you guys have ran the truck a bit do you think a MMpro ESC with a Novak Ballistic 8.5T motor would be enough to push this truck without heat issues and with good speed and torque?
Any help?
bigbeej is offline
Old 01-09-2010, 06:58 PM
  #633
Any help?
NOT SURE IM RUNNING AN LRP X12 6.5 W/ AN 11T PINION. THAT FEELS LIKE ENOUGH. WERE RUNNING A TIGHT INDOOR TRACK, BUT EVEN ON A 1/8 TRACK IT SHOULD BE ENOUGH. 8.5 MAYBE A LITTLE SMALL, BUT IF YOU HAVE ONE ALREADY TOSS IT IN AND SEE. IT MIGHT WORK FINE.
cbrociuos is offline
Old 01-10-2010, 08:33 AM
  #634
Trader Rating: 20 (100%+)
is the ofna diffs the same as jammin i know where I can get a ofna for 90bucks I have the jammin on order and was just wondering if enough stuff would fit to make it worth paying the 90bucks.
xxxtruck is offline
Old 01-10-2010, 08:45 AM
  #635
DieselBurner's Avatar
FRor you jammin guys, I have a jammin 1/8 scale for sale on ebay. the listing has all the info you'd ever need. have a look and it ends soon. ACT NOW!!
ebay item number:250558071430
DieselBurner is offline
Old 01-10-2010, 11:10 AM
  #636
So go post it in the for sale section. This is the SCRT10 thread, not the I've got an 1/8 scale for sale on ebay thread.
laedco58 is offline
Old 01-10-2010, 07:13 PM
  #637
russp's Avatar
So is it true the sc10 body will fit the scrt? I'm already in need for new skin for my truck
russp is offline
Old 01-10-2010, 07:50 PM
  #638
page31 post458
jnyrcr is offline
Old 01-10-2010, 08:07 PM
  #639
russp's Avatar
Originally Posted by jnyrcr View Post
page31 post458
awesome thanks. not a bad fit
russp is offline
Old 01-10-2010, 10:57 PM
  #640
russp's Avatar
Originally Posted by snrscion View Post
which body did you look at that was 52$. The Jammin body is only 34.95 with sticker sheet 40937.
That's not a bad price for a repacement body
russp is offline
Old 01-10-2010, 10:58 PM
  #641
CAK
Location: Breaking the land speed record with my 4.5HV in Kingwood, TX
Default Novak 4.5 HV Question
For those of you using the Novak 4.5 hv with the Havok Pro ESC, hows it working out? Think this would be a worthwhile upgrade over the Velineon system?
CAK is offline
Old 01-10-2010, 11:20 PM
  #642
I'm running the Havoc Pro/4.5 HV setup in mine. I haven't run the truck much, only had it to the track twice and run a total of 6 packs through it. On the tight indoor track I've been running at I can run for over 15 minutes and the motor and speedo are barely warm. I don't know anything about the Velineon system so I can't hep you there. The SC class at this track has been all SC10's so far so I haven't raced it yet. The other indoor track in the area runs on carpet and only run spec slash trucks...Those onroad guys like having a bunch of rules so they can find away around them. We run open class, you can't cheat if there aren't any rules to break
laedco58 is offline
Old 01-11-2010, 06:50 AM
  #643
does any body know
xxxtruck is offline
Old 01-11-2010, 07:26 AM
  #644
Racecrafter's Avatar
Trader Rating: 25 (96%+)
does any body know
Even though the ring gears are the same teeth (39) I think the Hyper may be thicker to enable it to reach the 10t pinion vs jammins 12t. Though I am not positive.
Racecrafter is offline
Old 01-11-2010, 12:38 PM
  #645
does any body know
maybe try to compare part # at nitrohouse?
jnyrcr is offline
