Jammin SCRT10 Thread >
Old 12-22-2009, 07:56 AM
  #376
The original crt.5 came with a set of both pin and hex wheels. The pins did require just the right washer/spacer or the wheel would drag on the bearing. The real problem with the pins was after some time those wheels had lots of play that the hexes did not have. In the end I swapped all my tires on to hex wheels.
GO-RIDE.com is offline
Old 12-22-2009, 08:49 AM
  #377
CAK
Location: Breaking the land speed record with my 4.5HV in Kingwood, TX
Default Up and Running!
Got the SCRT built, looks like a nice kit...BUT...OFNA, please revise the front bumper on this thing. Talk about made of glass, thats ridiculous for a SC truck thats gonna be banging fenders. How I'm I going to punt the Slash's off the track with a piece like that!
Thinking about trying to make the Hyper bumper fit...it's that bad.
CAK is offline
Old 12-22-2009, 09:07 AM
  #378
nitroexpress's Avatar
Originally Posted by lastresort View Post
What kind of white springs are you using. Are the whites stiffer than the stock setup?
The springs are the same as CRT.5
gray - soft
blue - med
white - hard
nitroexpress is offline
Old 12-22-2009, 09:24 AM
  #379
Originally Posted by Integra View Post
that's a toe plate...not an anchorman.
You mean ACKERMANN? Actually the original term mentioned in the original post "drag link" is not correct.
I believe, servo saver connecting plate or servo saver rack (OFN40895) would be more correct. So -
http://cgi.ebay.com/Ofna-Jammin-CRT-...item35a5960382
Old 12-22-2009, 09:36 AM
  #380
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
It's actually not an ackerman plate because it doesn't adjust the ackerman. That is done on the bellcranks on the jammin. You could call it a servo saver connecting plate, but it's actually a drag link. Doesn't really matter what you call it. It's a weak point in the steering.
JAMMINKRAZY is offline
Old 12-22-2009, 09:43 AM
  #381
Shark413's Avatar
Trader Rating: 24 (100%+)
Originally Posted by t3gt View Post
I like the fact that Jammin kept this truck "true scale", it might be a headache with the standard of tires that the others have set, but it definitely looks better and is a spitting image of the SC8--which IMO is THE BEST SC truck--So the Jammin should run and perform VERY similar to the SC8 (Kudos)--just in a slightly smaller package....
Shark413--the only thing I would watch for is stripping out the wheels using the pin directly to the wheel method...The Jammin will have more power then an SC10, and the SC10 wheels are prone to wheel stripping with high power brushless systems installed....Just a heads up for ya...
T3GT, good point, fortunately Proline did their homework and the slots are a bit beefier on the bead loc wheels. Still vehicle specific wheels would obviously be the best, but until then I just wanted to try different tires on the SCTRC10. Actually the stock wheels/tires have some advantages, more scale looking, lighter overall weight, lower CG, less unsprung weight, etc. The only minus is the lack of selection (treads/compounds).
Shark413 is offline
Old 12-22-2009, 09:48 AM
  #382
Shark413's Avatar
GO-RIDE, +1. You definetly need to be on your toes when using pins, over tigthen them and they bind, not tight enough and you could strip out the slot. One other thing, the SC10 uses 1/16 pins and the Jammin uses 2mm pins. 1/16 works out to about 1.6mm so the slot in the SC10 wheel is slightly undersized. I will look at it later and see how snug the Jammin pins fit and decide if I need to enlarge the slots.
Shark413 is offline
Old 12-22-2009, 11:41 AM
  #383
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
The Ofna boys will be at OCRC on Wednesday night for racing so bring your Jammin SCRT I need help running against those Hyper 10sc and Slash 4x4.
snrscion is offline
Old 12-22-2009, 12:25 PM
  #384
Integra's Avatar
we all know what it is.....who care's what the Real name is.
Integra is offline
Old 12-22-2009, 12:26 PM
  #385
lol I know.
Old 12-22-2009, 01:08 PM
  #386
Arigato's Avatar
lol I know.
So it's not this?
http://www.imdb.com/media/rm3874461952/tt0357413
Arigato is offline
Old 12-22-2009, 01:29 PM
  #387
Integra's Avatar
spelling correction Noted.
Wont happen again Spelling Moderator.
Integra is offline
Old 12-22-2009, 05:27 PM
  #388
Shark413's Avatar
Default Bumper
As I mentioned in an earlier post the first day out on the track I had a little accident and broke the front upper bumper support. It's been kinda slow at work this week so I figured while I was waiting for a replacement I could see if I could throw something together using some spares I had laying around. I had previously used a Slash front bumper on my 1/8 buggy SC conversion, it is pretty easy to adapt to other trucks, it is pretty tough and I had an extra one. So I took some scrap aluminum I had left over from some skids I made and put together a new front bumper for my Jammin using the Slash bumper. As a bonus I got a front skid plate as well. It took me a hour or so to make the parts and it bolted on without issue. The Slash bumper is very solid and has a built in shock absorber, unfortunetly it sits about 1/2 too high in relation to the body, oh well.
Here are the parts required, Slash bumper and some 6061 aluminum scrap.
Parts together
Bottom view
Front shot
Here it is with the body on.
Shark413 is offline
Old 12-22-2009, 07:06 PM
  #389
Rootar's Avatar
Trader Rating: 28 (100%+)
easy fix for the slash bumper... cut the top hoop off.
Rootar is offline
Old 12-22-2009, 08:14 PM
  #390
Shark413's Avatar
Default Size
Someone was asking about the relative size of the Jammin. Well I don't own a Slash but I do have an SC10 so here they are.
Jammin SCTRC10 and Associated SC10
Topless
Shark413 is offline
