Jammin SCRT10 Thread
#3196
how about part numbers for standoffs and 6 mm eyelets PLease
#3197
PS the losi stand off's should work if you pick up a set of shocks off ebay often the stand off's are included. May need to drill out the hole a touch, but easy mod.
#3198
Losi stand offs are 4mm x 10mm (threads that go into the tower), they will work but pretty sure the towers need to be 4mm thick. The stand off is only threaded to 3.5mm. I have the standoffs and waiting for my shocks and waiting for SNR to get more of the towers out so I can test. Jamminkrazy said the 8ight stand offs would not work because there is not enough material on the towers for the larger hole. Here are the mounts - http://cgi.ebay.com/LOSI-8IGHT-2-0-1...item3cab6159ab
And the 6mm eyelets, I was going to try these - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBM12
#3199
ttt
[QUOTE=SaladFork;7197283]Losi stand offs are 4mm x 10mm (threads that go into the tower), they will work but pretty sure the towers need to be 4mm thick. The stand off is only threaded to 3.5mm. I have the standoffs and waiting for my shocks and waiting for SNR to get more of the towers out so I can test. Jamminkrazy said the 8ight stand offs would not work because there is not enough material on the towers for the larger hole. Here are the mounts - http://cgi.ebay.com/LOSI-8IGHT-2-0-1...item3cab6159ab
Don't use those as they are the stock Losi standoffs, unless you ask SNR to make your towers with larger holes already drilled, otherwise run these:
Springs:
LOS 5455
LOS 5456
Caps:
LOSb2809
Standoffs:
OFN40531
Eyelets:
OFN30403
This is everything you need if you plan to run the Losi BB shocks
Springs:
LOS 5455
LOS 5456
Caps:
LOSb2809
Standoffs:
OFN40531
Eyelets:
OFN30403
#3200
[QUOTE=rcjunky10;7197666]
Chad,
Could you explain this shock thing one more time ????
If you are considering the Losi BB mod, DO NOT try to drill out the "standard" SNR CF towers if you plan to use the Losi 4mm diameter stand-offs. You won't have enough web between the holes and you'll probably crack or break the tower in short order. Same thing applies if you are using Jammin towers...then you need to use the set up RCjunky mentions.
SNR was nice enough to custom drill some of his CF towers for me with 4mm holes so I could use the Losi stand-offs and not have to use the plastic shock caps (which is required for the set up rcjunky describes). The only drawback is you have fewer holes (positioning options) since the holes are bigger and take up more real estate.
SNR provides both 3mm and 4mm thick CF towers. If you want to use the Losi stand offs and aluminum shock caps buy the 3mm thick tower or the Losi stand-offs won't have enough threads showing to fully seat the lock nuts on the back side.
Don't forget, if you use the taller front tower, whether SNRs or Jammin rear on the front, you have to use a rear body mount on the front.... regardless of which shock you use.
So far I love the set-up. SNR does nice work.
Springs:
LOS 5455
LOS 5456
Caps:
LOSb2809
Standoffs:
OFN40531
Eyelets:
OFN30403
Springs:
LOS 5455
LOS 5456
Caps:
LOSb2809
Standoffs:
OFN40531
Eyelets:
OFN30403
#3201
[QUOTE=Wldmoose;7198465]
Chad,
One other thing to consider, SNR provides both 3mm and 4mm thick CF towers. If you want to use the Losi stand offs and aluminum shock caps buy the 3mm thick tower or the Losi stand-offs won't have enough threads showing to fully seat the lock nuts on the back side.
Bruce I think they have just about got it....!
Chad,
#3202
Chad,
Yeah I had planned on talking with Steve about drilling 4mm holes for me. If not I will go the other route. This was mentioned quite awhile ago about the towers not having enough meat for the 4mm threads. I thought for sure the Losi stand offs had enough threads for the 4mm towers, but since you tried it I obviously am wrong. Thanks for the heads up!
Chad,
#3203
Just to toss this out there.....I run Matrix Carbon towers on my 8ight buggy and they are 4mm thick and the shock mounts bolt up no problem's....so the Losi standoffs are more then long enough for 4mm thick tower's.
#3204
#3205
Chad,
SNR would like to buy is their a web site
Chad,
#3210
I used the same size screw for the top, but a little longer, then used the 1/10th top shock mount off my XXXT. Using standard metal shock caps, a washer and a locking nut works great.
Will post pics when I get home.
Not allowed to post the url so you will have to cut and paste.
amainhobbies.com/product_info.php/products_id/15203/n/Team-Losi-Shock-Upper-Mount-Bushings-4-Front-Rear
