Jammin SCRT10 Thread >
Old 11-17-2009, 12:14 PM
  #226
rohrej's Avatar
Originally Posted by markhat250 View Post
The Jammin is coming with plastic shocks?!! What?
I may have to go Hyper.
I was disappointed to see that as well, however the shocks are relatively easy to replace, unlike modifying the weight balance or steering design. I like the forward weight bias of the hyper, but would prefer the c-hub steering of the jammin. This is not going to be an easy decision.
rohrej is offline
Old 11-17-2009, 12:42 PM
  #227
Plastic shocks??? That would be bad if Jammin down grades. The crt.5 and mini st both haver plastic upper shock eyelets, but the bodies are aluminum.
GO-RIDE.com is offline
Old 11-17-2009, 03:32 PM
  #228
rohrej's Avatar
What is common/different between the jammin and hyper as far as the drive-train components go? The new hypers are having problems with bending dogbones and CVDs, so I hope the jammin comes with stronger ones.
rohrej is offline
Old 11-17-2009, 08:25 PM
  #229
Yes the hyper has problems with bending dogbones. Even the hyper mini had the same problem, possibly even the CRT.5. One of the issues withe hyper is that under full compresion, the dogbone is bottoming out/going fully inside the inner drivecup causing binding. This is when the axle begins to twist/bend. The easy solution is to put an oring or 2mm of fuel line on the shock shaft to act as a bump stop, preventting the binding.
As long as the axle isn't bent too bad, it is fine to use still. I've been running the same slightly bent axles on my 1/8 with no problems.
aggie4231 is offline
Old 11-17-2009, 08:34 PM
  #230
Crawler's Avatar
I'm so amped to pick one of these up!
Crawler is offline
Old 11-24-2009, 12:52 PM
  #231
rohrej's Avatar
This seems like the kind of problem that a company who is serious about selling their product to racers would fix... Taking away suspension travel doesn't sound like a desirable option.
Any word on what the pricing is going to be for the Jammin? I have a feeling most people interested in a 1/10 4x4 SC truck will have a Ofna or Traxxas by the time these come out in January.
rohrej is offline
Old 11-24-2009, 03:20 PM
  #232
Crawler's Avatar
Ehhhhh, the Slash was available for months before the SC10 came out, doesn't seem to have hurt it's sales. Lot's of racers will wait for the Jammin.
Crawler is offline
Old 11-25-2009, 07:27 AM
  #233
R40Victim's Avatar
Since they have some distinct differences, there will def be some folks that wait to get the Jammin. However, unless they swap for metal shocks, the Hyper still seems like a better deal.
R40Victim is offline
Old 12-07-2009, 04:50 PM
  #234
rohrej's Avatar
Sure does. Anybody know if the suspension arms sill be interchangeable? i.e. will I be able to swap the c-hubs from the jammin in place of the pillow ball front end on the ofna?
rohrej is offline
Old 12-08-2009, 07:52 PM
  #235
CAK
Location: Breaking the land speed record with my 4.5HV in Kingwood, TX
Would the Velineon bl have enough power for this truck without burning up? I have an extra staring at me...
CAK is offline
Old 12-08-2009, 08:12 PM
  #236
Trader Rating: 54 (100%+)
Where does it say plastic shocks?
w_dupree is offline
Old 12-08-2009, 09:02 PM
  #237
Trader Rating: 22 (100%+)
When will it be out?
Honu is offline
Old 12-11-2009, 09:01 AM
  #238
It would add another $60-$100 for the aluminum shocks..I'd probably go with ofna, instead..
roosterkill is offline
Old 12-11-2009, 11:29 AM
  #239
chevydc44's Avatar
Trader Rating: 35 (100%+)
What would be a good motor to put in these 4wd trucks
chevydc44 is offline
Old 12-11-2009, 12:05 PM
  #240
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
This Jammin come with threaded aluminum shock.
snrscion is offline
